Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
resonanceman
Quote from: sm0ky2 on October 17, 2008, 12:31:38 PM
I'm just saying the guy that wrote that doesnt know what hes' talking about, yet he seems overly motivated to present this nonsense to the world.
SmOkey
The part of  your  post that I quoted   is  exactly the  wrong  kind of thing to  write  if you  want me  to  respect  your  views .
I am sure  you have a  good education in  these areas  .
I am sure you believe that  you    know  enough  to  make these kinds  of statements  with   with convection .
It is not  your  intelligence  or  your honesty  that I question  .  I question  the  education that you  received .
Are  collages   supported by big energy ?  my answer is  YES .
Does  big energy  use  there influence  in collages to have the  curriculum " tweaked ?"  My answer is YES .
If   the  curriculum is tweaked   to explain away  the possibility  of  OU   would you know it?
My answer is NO .    They have been  doing this sense at  least Teslas time .  The curriculum  has been fine tuned over many years .
Has  technology  related to energy  grown at the same  rate as other technologys?    My answer is NO .    The tweaking   of the truth  has made  progress almost non existent .
The fact that you  say it is nonsense  or impossible  means nothing to me.
In my opinion a small part of your education was actually  brainwashing .
It may take  someone like me that you  can  honestly think of as ignorant  to  see the real  possibility's .
As  far  as the PDF .
My opinion  of it  is that  it was probably written  by someone that  worked on  Electrinium  in some way  in the past .   The  technology  was  suppressed or   used only in  secret  areas .
The  first part of the PDF  tells me that the author   looks at the  bigger  picture  about life.
He  would  have felt  very bad about  electrinium  being  kept secret .
It may  have  seemed to him  that it was his  biggest  sin.
An anonymous PDF  placed on the internet  might have been the best he could  do to  relieve the guilt .     I know that if I  had  proven  energy technology    and  wasn't sharing  it  with  the public  I would feel like I was killing my grandchildren .
I might  be  wrong  about  this  stuff .   My education is not  that good  , but I have learned  a few things  outside of school .
I will continue to work on Electrinium   no matter what the " experts "  say .
gary
nievesoliveras
Hi!
@gary
Thank you for the information about the lead batteries. I will need now to make another decision about the electrinium source chosen.
@sm0ky2
You said that "growing the crystals in a permanent magnetic field may achieve the same result, without the need for a live coil running for several hours." and "...the crystals COULD BE grown in side a cylinder magnet..."
My question is:
I will put magnets aligned north(+) south(-) for the compound molecules to get aligned as the earth alingment of poles. I mean the compass north, points to the earth magnetic south, and the compass south points to the earth magnetic north.
Am I correct? Or the magnets go the other way around?
I am self taught and did not study theories.
Jesus
hypersoniq
seriously look into filtered respirators and Cyanide Antidote Kits (Sodium Nitrate and Sodium Thiosulfate ) before continuing on the Cyanide path...
cheapest antidote kit I have seen was over $400.
and don't work alone! have someone far enough away to be clear of the cyanide (in ANY form) but near enough to come administer the shots if needed.
nitinnun
the zero point energy molecule !
copper atom collects/stores positive charge.
iron atom collects/stores negative charge.
polymer MAGNETICALLY connects copper and iron.
but ELECTRICALLY disconnects them.
so that coper/iron may charge up, but not short each other out.
two ZPE molecules connected in parallel, increases amperage.
two ZPE molecules connected in series, increases voltage.
if you place a stick of copper,
and a stick of steel,
into a cup of elmers school glue,
than EVERY ATOM on the surface of the copper/steel, counts as a ZPE molecule!
but since the above ZPE molecules are connected in PARALLEL, only amperage stacks!
while voltage stays the same.
that is why i get mroe amperage, for more metal surface area. yet nothing, for more metal mass.
what someone NEEDS to do, is make a crystal lattice.
where each molecule in the crystal lattice, has 1 copper, one iron, held apart by a third atom.
(carbon or silicon?)
to melt glass, ancient people just built a brick/stone oven, and fed fule into it.
the heat built up inside the oven, just like electricity builds up in a capacitor.
until there was enough stored heat in the oven, to melt silicon dioxide into glass.
Dr. Tesla
Quote from: mrcharisma on October 16, 2008, 10:03:00 PM
You would think someone going by the name of "Tesla" himself would know better!
lol
Matt
And what are you refering at? Can you be more speciffic?
Kiddo, make sure you get me on something real. I am happy to take the flack for my errors. No one is perfect. At least, if I say something stupid, 'llI admit it. Those "working" on a battery reconditioning process here (and call it so esoterically electrinium...how passe'...) would never do that.
'Coz in essence this whole electrinium thing is about re-conditioning the sludge to hold the charge again. In case you and them haven't noticed. And that has already been discovered and studied by scientists long time ago.
