Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
forest
I have such concept ; we need 3 elements:
- rotating magnetic field + a power source to sustain it at constant start speed
- output coil
- element which accelerates rotating magnetic field to generate exactly required power for connected load to output coil, it may be called control element
It's obvious that rotating magnetic field must be able to move alone without power source connected directly, because acceleration of it will broken any electronic generator.
It's obvious that between all elements Lenz's law principles must be used to keep acceleration at safe level and remove runaway probability.
There is another possibility not related to magnetic field , but that idea is too crazy to mention it now.In that second idea rotation speed is constant value depended maybe only on device diameter, but I can't imagine how magnetic field would behave in that situation and everything else also...
Antimon
Guys, please don't forget the physics.
Power=torque*2*pi*frequency
It doesn't matter how fast you spin, you will never get overunity. In this case its only possible when you overcome lentz law.
A.
sparks
    There was another gentleman who went about the task of rectifying AC and built a MAGNETIC DIODE and got alot more out than in most probably by accident.  Daniel McFarland Cook.  This is basically a couple of old school ignition coils hooked in an interesting parallel configuration and excited by an ac pulse.
    Another interesting effect is the acceleration of a dcmotor when there is no external field to limit it's acceleration.  As the armature accelerates it needs less and less current from the battery.  At what rpm will the armature need microvolts to further it's acceleration.  At a million 5million probably about the time the armature rpm gets beyond the speed of light and we cant find the commutator anymore.
   Move the fields and the mass will respond.  Move the mass and the fields will respond.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
perepiteia is negating Lenz's law for example
sparks
    Lenz law applies only to physics residing in the same inertial frame of reference without consideration of spacetime curvature or vacuum fluctuations about a field of mass.    It is a specific case mathmatical solution of maxwells equations and far from the last word on induced voltage.   It should be called the lenz effect not the lenz law.
Think Legacy
Spread the Love
