Pulse Generator
Started by slayer007, October 31, 2008, 07:42:52 AM
Groundloop
@gyulasun,
Thanks for the input. Yes, I have the means to build it if I want to.
The 470 Ohm base resistor is low because I want fast switching. The current
through the transistor is limited to 1 ampere by the 12 Ohm resistor. I do not
want to fry the 1,5 amp regulator.
Groundloop.
Groundloop
gyulasun
Quote from: Groundloop on November 01, 2008, 12:32:01 PM
@gyulasun,
Groundloop.
Dear Groundloop,
OK, I understand and accept your explanation.
If the patent is correct (and it seems to be, I think) then flux transfer between two adjacent (ferrite or other permeable) cores is going to happen, depending on the distance (air gap) between them. Figure 6 seems to utilize induction from one stage to the other, adding up power induced stage by stage.
Here is a link to the Japanese patent at the EPO: http://v3.espacenet.com/publicationDetails/originalDocument?CC=JP&NR=2003009558A&KC=A&FT=D&date=20030110&DB=EPODOC&locale=en_EP
Keep up your good work.
rgds, Gyula
Kator01
Hello Groundloop.
please have a look here :
http://www.overunity.com/index.php?topic=5950.msg135440;topicseen#msg135440
This design does not work, its a waste of time. I recommend the true bypass-controlled MEG described here :
http://www.overunity.com/index.php?topic=4300.msg135309;topicseen#msg135309
Best Regards
Kator
Groundloop
@gyulasun,
Thanks for the patent link.
Groundloop.
