Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
SkyWatcher123
Hi folks, im replicating a small model based on this youtube video that seems as though it can work around lentz, so that it does not reflect back to prime mover. I'm filling the holes in my ceramic ring magnets with epoxy right now since they are large holes. If the periphery rotatable disc magnets are able to be influenced to rotate and relieve pressure from lentz effect of coil then it should work, he has other videos that appear to show an actual speed up of main rotor when coil is loaded. I will know soon enough once mine is put together.
peace love light
Tyson
http://www.youtube.com/watch?v=etFCzIe-D2Y&feature=related
sinergicus
Quote from: sinergicus on March 17, 2010, 05:11:50 AM
n my seeking to find a way to obtain easy end cheap free energy, I found this patent in PJ book
RapidShare: 1-CLICK Web hosting - Easy Filehosting
This was very interesting to me ,because seems to be very easy to replicate.
My ideea is to put this generator in conjunction with Osiie Calanan free energy unit
http://www.google.com/url?sa=t&sourc...TYd5jc3ndQJ03w
You can find discussion about this, Here
Radiant Free Energy By Ossie Callanan
Excerpt from patent:
"This unique way of generating electricity allows generation of more electrical power, e.g. anywhere in the
range of 4 to 137 times more power, than prior, conventional means. It also has the advantage of obtaining
unity power with very little effort. "
With this type of generator,no need shaft torque to fight against lenz force.
We can recover entire energy from Ossie Callanan motor-generator section
and in the same time,we will have common power usable directly from this lenz less generator.
I want to give it a try and make replication but I have some misunderstanding
about this .Seems the information are not complete .For example the fig 4 are not explained.
My unclarity regarding this generator are:
1.Cannot see the difference between , interaction of magnetic field of magnets with coils in common generators with lenz force and interaction of the magnetic field in this lenzless generator. Only difference I can see is the
position of the magnets in reference with coils.
2.The magnets are interacting with coils with both N and S poles or just with upper part of them (with one pole facing the coils) and the other pole being
bellow of the core?
3.The magnets must interact between them via steel shaft(?) or this is no necessary ?
4.Can be used rectangular magnets (SSG Type) and staked them to have the surface necessary to interact with coils?
If somebody have a better understanding of this invention by reading the patent, please post here ,to help me ,(us) to understand in deeply this type of generator ,and start to make some experiments.
Mike
I hope this tread are not died
Sorry for missing that links.I opened an topic on energeticforum.com  with the same subject.I put here the same words (with copy -paste)  ;D
Seems the links was missed ...
Here is :
http://rapidshare.com/files/363992008/Alternating_curent_generator_lenzless.pdf
http://www.overunity.com/index.php?action=dlattach;topic=1868.0;attach=5087
http://www.energeticforum.com/renewable-energy/3062-radiant-free-energy-ossie-callanan.html
DreamThinkBuild
@Tyson,
Thanks for the link, haven't seen that one yet. The idea makes sense though. In a normal generator the coil and magnet are fixed. As they get near since neither one of them want to budge the EMF/Lenz sets up a resistance which induces drag. Now if the magnet is just able to be spun/rolled (wrong term, more like pulled by Lenz pushed by EMF) away it will greatly reduce the drag.
It looks like from the video that the more load it speeds up, could be that the magnet is forced/rolled away at a greater velocity. Would have to build to see real measurements of what is going on.
http://www.youtube.com/user/Th3Generat0r#p/u/2/_9ktD7kAI7Y
SkyWatcher123
Hi dreamthinkbuild, thanks for reply to my post. Yes the second i saw this video, i said this has to work, drilling center holes in my magnets today and i have to build a wood mounting setup for it all. If i were to take a guess, i would say that as the disc magnet is leaving the generator coil and since it is spinning in opposite direction to main rotor, it may be generating a repulsive force similar to what normally happens when a magnet approaches a coil, but in this case its spinning so repels away from coil as Wendell Ray Walker pointed out in his video i posted. Now if it is generating another similar pole as it leaves it may not quite be AC but more like an almost pure DC, but that doesnt matter much, since we generated current on approach and get a free repulsion kick on departure from coil which would explain the speedup, so if it works this way, it's a beautiful machine.
peace love light
Tyson ;)
