Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
supermuble
Really? On a news article it said it was 7000% over unity, and tests were done to prove it? Well I guess I'll go back and re-read everything.
hartiberlin
Here is somebody from youtube who also has a No Lenz toroidal generator.
He can show it already.
http://www.youtube.com/profile?user=bjusticeforever&view=videos
Seems to depend really on all setup parameters like
length of magnets coil length, airgap sizes, etc...
Regards, Stefan.
Kator01
Well, as I see it he is using a closed magnetic-flux. It looks like a flyback-core. Now some guessing about this driver-motor : 500 Watt ?
Output : 2,5 Volt at 10 amps.= 25 Watt
I do not think a 500 Watt-Motor will slow down noticable by just 5 % load of it nominal power.
We have to invite that person to Thanes topic..
Kator01
supermuble
If you notice in the video above, if you remove the toroid core, there is still no way you can have effective drag caused by Lenz's law. If the magnets are spaced in a NSNSNS configuration, then there is no Lenz's law.
Imagine that the magnet pulling away from the coil of wire is a south magnet. It will try to create an opposing field (north) in the left side of the coil. On the right side of the coil, a north magnet is approaching and is trying to create an opposing field (north). Two sides of the coil are equally trying to create a north field.... How can this have a Lenz's law effect? It can't. It is the same concept exactly as the Bedini-Cole window motor.
It appears that magnet spacing and configuration as well as the layout of the wire is easily adjusted to remove Lenz's law. Proof is in the Bedini-Cole window motor videos.
sparks
    What happens if we control the reluctance of the circuit so that as the magnet approaches it begins to flip over magnetic domains. The coils are placed deep in the back iron.  There is going to be a delay as the steel takes it's time spreading the magnetic domains..  By the time the coil current starts flowing and the countering magnet field produced the rotor permanent magnet is long gone.  This doesn't mess with Lenz law it is just a matter of timing.  The below diagram uses some ringing to get into overunity.   Remember this circuit works off of magnetic domain flipping.  What force unsaturates a core?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
