RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 50 Guests are viewing this topic.
gotoluc
Hi Groundloop,
they look 8) real good ;D. Thank you for your dedication to help so many of us.
@everyone,
my daughter's visit with me is done so I'm back to my coil tests as of tomorrow to try to find the one that best charges a 5AH 12vdc sealed lead acid battery before closing the loop.
I'm not sure how many days this will take but I will keep you informed of the progress.
Stay tuned
Luc
Is this the version that uses the pic16f84a and allows push-button storage setting of a frequency?
I've already got the chip and the transistors etc.
Groundloop
@TinselKoala,
Yes, but I have not made the software do the storage thing yet. The first software will use the run stop
switch just to do that, run or stop the switching. I will work on a better software later on when time permit.
Attached is the software version 1.0. This software will take the input from the signal generator and control
the optos. My main task right now is to get ready one unit to do testing on. The push button frequency
storage must come later.(If it is doable, that is.) If you want a new pcb then PM me your snail mail address.
Groundloop.
turniton
ok, so i get basically the same thing here. but how do we efficiently down convert this voltage/current in the cap (500vdc) to something more manageable?  (say 110 or 220v) (some kind of converter?)
any ideas?
it should be simple...
najman100
Quote from: Groundloop on January 15, 2009, 04:51:32 PM
Hi All,
I have received the new PCB's for the micro controller H-Bridge switch and is currently testing the software.
I will need a PM with a snail mail address from:
@Fausto
@Wattsup
@TinselKoala
@ramset
@duff
I will snail mail the boards as soon as I get an address to mail to.
Attached is a image of the new switch.
Have to solder on the transistors and put the circuit into a plastic box.
Best regards,
Groundloop.
Cant wait till i receive mine  ;D ;D ;D ;D
Thanks Groundloop
Najman
