Induction motors and capacitors lowers amps "consumption"
Started by Kyoat, January 19, 2009, 03:45:21 PM
nueview
information for all interested the emerson windings read .8 ohms per coil  and the delta reads 2 ohms for the run windings.
hope this helps everyone.
good luck with your projects.
nueview
spinner
Quote from: Kyoat on February 02, 2009, 06:22:02 PM
I thought these results were both fascinating as well as what I would consider to be unexpected results.
The following test results were conducted on an Emerson 1hp, 1ph, 60hz motor.
We were tyring to find the "sweet spot" for capacitance across the primary coils for the lowest VAR watts "consumption"
We were using a KILL A WATT model P3 meter.
Capacitance:    Amps:        Apparent watts:        VAR watts:           Power Factor:         reduction %
     NONE          9.63                203                      1146                      .18                     00.00
  Kyoat
Well...  just check out your "Kill a Watt" meter....
I've never seen a motor with a PF of just 0,18.... ??? My worst was a PF 0,52.....
But..., I never saw Aliens, either....
That must be a World record..? I mean, for a serial (market) device ()...? PF=0,18???
How screwed up devices there really are???...
"Ex nihilo nihil"
Kyoat
Quote from: spinner on February 04, 2009, 06:55:39 AM
2-3-09
I wouldn't know about a "world record", we have two (2) of these Kill-a-watt meters, one is brand new.  I will double check this reading the next time we run tests, comparing the readings of both meters.  It's entirely possible that one of them is malfunctioning, though I doubt it.  When we take these readings, we always allow a few seconds for the numbers to settledown and stabilize first.  You say you have never found one below .52 huh?  That is definitely strange, I have two (2) that do.  I just checked my notes for both motors, and the Delta motor was as follows:
  Caps:       Amps:        Apparent watts:     VAR-watts:        Power Factor
NONE        7.32               178                     877                     .19 <----------
  150uf        1.66                169                    203                      .85
.151uf        1.65                171                    201                      .84
  152uf        1.64                168                    196                      .84
.153uf        1.65                170                    198                      .85
One would think, that if the meter is malfunctioning, that it would also do it with capacitance as well, but I'm not sure.
Thanks for the feed back.  Kyoat
  ________________________________________________________________________________________________________
2-4-09 Follow up on question of PF readings:
We tested 4 different motors today with one meter that is about 3 years old, against one just purchased last month, and here is the results:
                                                 Amps:         Apparent watts:        VAR-watts         Power factor:
Emerson motor: Old meter:        9.63                 202                         1148                  .18
                        New meter:       9.61                 203                         1141                  .18
Century motor:  Old meter:         7.52                192                            906                  .21
                       New meter:        7.50                189                            904                  .20
Delta motor:      Old meter:         7.30                173                            878                 .19
                       New meter:        7.26                 169                           868                  .19
G.E. motor:       Old meter:        5.21                 135                           627                  .23
                        New meter:       5.18                 145                           623                  .23
Sooooo, I don't know what to say except that maybe YOU might have a malfunctioning meter.  Anything is possible.... even Aliens!
Or is it possible that your power provider is not using the "same" power factor calculation as ours?  My guess is that "they" all use the exact same formula to screw us all the exact same amount, (as much as they can).  Kyoat
Remember, Wilbur and Orivil Wright, against all odds demonstrated to the world that with a little tinkering and alot of thought, that man could fly.  All the while all the "educated men of the world" said man would never leave the ground.  97% of their calculations are still used today.  Not bad for two bycycle repairmen. 3% error!
Kyoat
 ;D
Well we just got word that our Inverter will be shipped Monday the 9th.  We will post our results ASAP  Kyoat
hoptoad
Quote from: Kyoat on February 09, 2009, 02:28:16 AM
;D
Good luck ... am looking forward to your data
Cheers
