Anti-gravity Motor! (Everyone please read, very important)
Started by gravityblock, February 21, 2009, 12:42:26 PM
gravityblock
Let's assume the below is correct for a moment.
1)  CF force in all directions are equalized = Zero gravity.
2)  CF force in all directions are equalized except for 1 direction (down direction is predominant) = Earth's Gravity or linear direction downwards.
3)  CF force in all directions are equalized except for 1 direction (up direction is predominant) = Anti-gravity or linear direction upwards.
4)  Predominant CF force = linear direction in the predominant direction of the CF force.
Does this help?
gravityblock
A coaxial rotor within a coaxial rotor, perpendicular to each other, in the form of a gyroscope or gimbals is the key I have been holding back.
An example of a coaxial rotor is a helicopter with no tail rotor.  http://en.wikipedia.org/wiki/Coaxial_rotor.
Now imagine a coaxial gyroscope rotor.
gravityblock
Gyroscoop coaxial video
http://www.youtube.com/watch?v=xMV29qjjJ4E
This just needs to be taken 1 step forward with a vertical axis perpendicular within the horizontal axis (magnetic wheels and not blades).  This will not be using air for lift, but will be a true anti-gravity machine.
gravityblock
The electron travels in a corkscrew motion around a conductor wire.  This corkscrew motion is the angular momentum of the electron.  In addition to the angular momentum, it is spinning around it's own axis, and this is the axial momentum of the electron.  The axial momentum undergoes Lenz's law.  It is the orbital momentum that overcomes the Lenz's law to give us torque.  When you wind the wire around a conductor material, you're increasing the torque that is available (increasing the magnetic field), due to increasing the angular momentum of the electrons by the number of turns of the wire.  The angular momentum of a unidirectional force, such as a gyroscope does the same thing.
Nasa even uses a gyroscope type device to create artificial gravity.  They use a motor within the gyroscope to move the gyroscope wheels to create artificial gravity.  Use a motor on the outside of the wheels, one on each wheel, not to create movement, but to create anti-gravity within the object.  In addition to the motor on the outside of the wheels, have a motor on the inside of the wheels.  The motors on the outside will allow you to determine direction of movement by creating a Lenz's force on the inside motor, which causes the wheels on the outside not to turn (this is the same as putting a heavy load on a motor) and the motor on the inside to provide torque to the other wheel.  This is nothing more than reversing the gyroscopes function, from creating gravity to creating anti-gravity.  It is using 3 motors to reverse gravity or flip gravity.  Nasa is only using one motor in the gyroscope to create gravity.  In Ezekiel, it says the wheels/motors on the outside do not turn. The motor/generator on the inside is turning, but Ezekiel wasn't able to see this. Instead of turning the wheels on the outside, it is turning gravity or flipping gravity by using Lenz's law to create a force against the direction of travel, thus propelling or pushing it through space.  The motors will be acting as either a generator or motor depending on the direction of travel.  It comes down to the triune force or the trinity force.
If one really thinks about this, it should become very clear to you.  I feel like I'm trying to beat a dead horse to awaken........lol
I may not have this totally correct, but this is the path for anti-gravity and OU.
gravityblock
The fact that an airplane takes a parabolic path for the affect of weightlessness is proof that the gyroscope using an unidirectional force can achieve an anti-gravity affect.
A parabolic path has a vertical and horizontal angle,  and the gyroscope can provide this same motion in all directions with coaxial rotors on both the vertical and horizontal axis.  The top horizontal half of the gyro will have more G's than the bottom half of the gyro.  Now we have a potential in the G's that can be exploited to our benefit for an anti-gravity affect on the entire object that will be opposite to the affect of earth's gravity.
