Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
0 Members and 18 Guests are viewing this topic.
h20power
Quote from: alan on June 20, 2021, 11:22:05 AM
I think Meyer never mentioned the resonant frequency of water, only resonance of the LCL charging network, so a high Q voltage forms over each component. Then  phase manipulation  by means of the coil setup (partnered opposite output coils) must oppose / delay current while allowing polarization through displacement current by an external voltage field instead of the charge integral. Polarized water creates a voltage by itself, that's probably how the watercap will hold an electrostatic field potential, until it releases electrons (ionization) and the covalent bind breaks and the electrons can be consumed by the amp consuming device. Current is equal, each component's voltage phase differs.
correct me if I'm wrong.
Hello Alan,
This is a RLC setup for as far as I am aware of water doesn't have a resonant frequency and in Meyer's setup is just part of the Voltage Intensifier Circuit being used as a dielectric liquid and a resistor that completes the circuit path way. When the transformer is wired correctly it is all wired in series on the secondary side that is to say the start of one coil is connected to the end of the other as shown in Meyer's dot diagram. The dot represents the start of the winding of the coil and shows how one it just wired right into the other in series with the capacitor which is also a bunch of little capacitors wired in series. The WFC will not work if water isn't part of the setup as it's needed to complete the series connected resonant cavities so, no water no series circuit.
The blocking diode has only two conditions, it is either ON or it's OFF and from there you can map out which way the current is flowing. When the switch is ON representing a closed circuit condition current is flowing from the capacitor as it discharges through the transformer coils as those coils are wired to the capacitor in a way that directly shorts the capacitor out. When the switch if OFF current is flowing from the chokes to the capacitor as it charges up the capacitor. Meyer tries to illustrate this in figures, 7-5, 7-6, and 7-8. Note that he doesn't even show the secondary coil at all because the blocking diode switch is OFF thus making it an OPEN circuit. What makes this Voltage Intensifier Circuit so special is how it mimic's a thunderstorm electronically. The part that I figure out that is so important shows how a thunderstorm works in that they are capable of breaking down any molecule that finds it's way into them to include the water molecule. This part of what I shared isn't fully understood in the scientific community and thus isn't in any textbook for one to read and study from. Trust me if they knew this no plane would be allowed to fly through an active thunderstorm as it's engines could ignite a pocket of hydrogen and oxygen gas that was generated by the bottom of the storm system headed to the top of the storm to make thunder as it gets ignited by the top of the cloud. You have felt this explosion taking place in the clouds overhead as it shakes the ground on which you stood upon. That ground shaking thunder you experienced was a hydrogen and oxygen explosion taking place in the clouds over your head. Basically what I found in my studies was things mainstream science missed as they rushed to say they knew all they was to know about something as from what I was able to find out clearly they didn't understand all that was going on when mother nature breaks the bonds of the water molecules as that very question was never asked by them. And since they never asked the question in the first place then how could they ever answer it? This is the importance of my work on all of this filling in the missing parts that the scientific community missed as they rushed through their work in trying to explain things.
Hope that helps you understand this a bit better.
Take care,
Edward
kolbacict
QuoteI still do not see why you just don't fully copy what Stanley Meyer did and go from there?
No no. I do not need employment. I somehow myself.
It's just that I'm very lonely here.
Am I going to you?
kolbacict
And if instead of the second electrode in the cell, you use the capacitance of a solitary conductor.
Which is not connected to anything, but has enough capacity.
Provided that the frequency is high enough.
A certain volume of water can be used as a secluded container.
h20power
Quote from: kolbacict on July 01, 2021, 03:25:39 PM
I have no idea what you are talking about and since you prove to me that you just don't want to do things the right way following my lead I think there is no hope for you ever being able to get this technology up and running. I laid out practically everything concerning this technology, gone over key concepts in great detail multiple times, and still you just don't wish to do things the correct way. I'm not sure but just maybe there is but one way to get this technology to work as I have seen people like you try every other way out there, except the right way, known to man. Everything you have done up to this point has ended up in failure but for reasons unknown you simply refuse to do things the proper way as I have laid out in this thread. Perhaps I was wrong about you and if so then there's a good chance this technology just isn't for you as the way you are heading you will never be able to get this technology to work.
Once I have enough funds to get the rest of the equipment I need I guess I will get started on seeing what I can do to get this technology into the marketplace. I know it's not going to be easy as those that wish for things to stay the way they are while the earth is showing clear signs that we must change away from the use of fossil fuels are still trying to keep this technology out of the marketplace. Sure, the earth will still be here but that's missing the point as the real point is will the earth still be able to support life as we know it?
The only way that I can see humanity starting to do something to fix the damage we have all contributed too is with this technology. I don't see any other technology out there that works with mother nature as this technology does. As a result I have doubled my efforts to raise the funds I need to be able to move forwards with this technology. I wish folks on this site would willing choose to give me a helping hand financially as this is going to be a major undertaking to get this technology into the marketplace where it can start turning the tide on our climate change problems. It's going up against all that mine, process, sale, and distribute energy, which is to include the fossil fuel industry and any company that sells energy by way of moving that energy on the world's grid supply network. The whole thing needs to be changed for us to have a chance at turning the tide on our climate change problems.
Shalom Everyone,
Edward
kolbacict
RF energy can be injected into the cell over a single wire. The second electrode can be a solitary capacitance. Is not it ?   ;)
