Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Hello Everyone,
I've been trying to see what I can get the old 8xa circuit to do as far as high voltage but it's tough as the circuit truly wasn't designed for it. For some reason it loses the ability to control the pulsing at only around 45 volts input from the variac. With the Voltage Intensifier Circuit things are different as it's a resonance circuit and getting high voltage isn't all that hard to do if things were built correctly. With this old 8xa circuit I think I'd have to change the SCR switch and make a much larger bifilar choke coil. Unless you truly know what you are doing none of you should follow my lead on this as this high voltage is dangerous and must be respected at all times coming from a microwave oven transformer. Here's the video: [size=78%]https://www.youtube.com/watch?v=vMebmZfiOAQ[/size]
Once I have the wire tensioners I'll be able to wind up the VIC transformer and use the 10 resonant cavity WFC. I'll more than likely make several different designs to test out too see which one works the best and is most cost effective.
From my research the plate WFC would need around 1650-1900 volts to reach the threshold for ionization and the 10 resonant cavity WFC is going to take around 8.5-9.5kv to reach the threshold for ionization. The plate cell puts a high load on the transformer due to the plate spacing being so close. The resonance WFC is much the same as Meyer's so not that much of a load will be placed on the VIC transformer. The highest voltages I took the plate WFC up to thus far is around 500 volts but it loses the ability to pulse it correctly at around 335 volts.
Anyway, once I have those wire tensioners I'll be able to get back working on the resonant WFC. This will more than likely be one of the very best built transformers ever done by someone as I am using a coil winding machine. It's sure going to be nice to see just what these newest line of transformers can do once they are built.
Take care all,
Edward Mitchell
Owner
True Green Solutions
https://gofund.me/94431e56
Vortex 22
Hello
The question?
WFC is it
a water capacitor?
Polar capacitor? With very low capacitance?
No more questions!
Merci
h20power
Quote from: Vortex 22 on December 19, 2022, 02:41:14 PM
Hello
The question?
WFC is it
a water capacitor?
No more questions!
Merci
Direct answer is YES it is a capacitor. Is it a polar capacitor? Perhaps as the dielectric that goes in it is polar but I am not sure of this. The capacitance is on the low side say around 25-100 pF but that changes with the distance or spacing between the plates the closer the plates are together the higher the capacitance the WFC will have. Just know that this is a variable capacitor as when it starts producing gases those gases displace the dielectric fluid, IE water, that is between the plates causing the capacitance of the WFC to go down.
I hope that answers your questions and more, and thanks for the questions.
Edward Mitchell
Owner
Vortex 22
Quote from: h20power on December 19, 2022, 09:20:23 PM
Edward Mitchell
Owner
Hl Edward  Mitchell,
It's very nice to hear from you!!!
Merry Christmas
Best Regards
Vortex 22
h20power
Thanks Vortex 22,
Just know I am very busy trying to finish up this technology as I hope to have it up and running sometime next week or in the beginning of the new year. Once the stuff I just ordered comes in I'll be able to finish this all up.
It's time to see how I do compared to all the others that tried to bring this technology out. Hopefully now is the right time and I don't end up like all the rest.
Shalom,
Edward Mitchell
Owner
