The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
Thaelin
 Well, getting some through put from the coils. Charged up a 20000uf 50v cap and when I turned on the light, pow went the filament. So at least I am drawing "some" useable power from it. Takes a while for it to happen but on the way there.
Still trying to fathom out how to make this thing self generate yet tho. Still chaseing it.
sugra
ronotte
Hello to all,
I'm a newbie, just  one of those that you say are following but not sharing anything with the few guys which are actually experimenting. Well I'm now so concerned with TPU that I find myself thinking about it also when it is supposed to do other things! So I've reached the following conclusion that I like to share. May I ask your opinion/help about this, just before starting to assemble my project?
Geometry:
Let me assume that this TPU is structured on 2 rings, one over the other, with a between distance of let us say 2 Inch. The rings are just house garden hoses. The ring diameter is 10 Inch.
Purposes:
The under ring is the continuous power generator, the upper ring is for generating auto start voltage surge for the initial powering of the under ring (actually it is my opinion that this ring could be better positioned just around the under ring itself).
Under Ring architecture:
The under ring is composed of 4  air coils at 90? plus 1 collector coil wrapped over the others and wound in bifilar way. Each of the 4 coils is simple straight windings, may be each one up to 3 segments that may be put in series or parallel...
Upper ring architecture:
The upper ring is composed by a magnetic loop Antenna tuned to .....5,0 KHz?. The antenna output is rectified with a germanium diode and properly fed back to the lower ring in series (protection circuits must be provided).
Operating considerations:
1.The TPU must have a kick generator for the auto start. This kick could be supplied by the sudden insertion of a magnet near the upper ring itself (The Antenna) . First of all I've to verify/optimize the rectified output coming from the HI Q tuned circuit. This output must not be levelled, as the voltage is transient e.g. is rich of harmonics that are what we are looking for. The voltage spikes so obtained are fed to the generator collector ring (one of the bifilar winding), may be I've to exchange polarities.
2.The generator ring has: 4 windings connected a-la-Tesla in order to obtain, when properly driven, a rotating field; a collector coil bifilar winded with purpose to obtain:  a tuned circuit (5.01 KHz?) that excited with the spike pulses rich of harmonics but with a base frequency 5,0 KHz resonates and coupled to upper ring enhances the spikes there produced so increasing number and amplitude of the spikes themselves. The little frequency difference does produce, as the signal combines (+and -) in the upper loop, double size spikes so increasing in an exponential way the voltage.
Note: may be that the correct resonance frequency  (of the antenna)is just provided by the presence of the starting magnet.
3.As the voltage reaches a good level (few Volts?) a passive circuit drives in quadrature the collector coil.
4.We should have now a sustained horizontal rotating field.
5.I forgot to say that I've put in the toroid centre a vertical strong Magnet.
6.As the horizontal field rotates it cuts the vertical magnet vertical field of the central magnet. This cutting is done at 5KHz and does produce a very strong auto-induction on the collector winding so should be possible to extract power from the free collector bifilar winding a-la-Marinov with all the sides effect about local ionization, gyro, plasma,?.
I intend to start building the magnetic antenna and see what kind of output I'm to find for the 5KHz resonance. Perhaps, considering the oscillator approach that I intend to use with the lower ring would be necessary fractions of Volt.
Sound interesting or I've to forget all?
IdentFlyObj
Hi,Ronotte.Germanium diode has got a maximum forward voltage drop of 0.3 Volt.
You can excite the upper antenna using a magnet,but there will be only a few milliVolts.....and harmonics will be a few microVolts.
fcpeace17
Quote from: Dingus Mungus on November 22, 2006, 09:12:23 PM
Quote from: Mannix on November 22, 2006, 08:58:03 PM
Give it away?
and how would you do that?
Schematic maybe? drawings? component list... I got more suggestions if needed...
Perhaps allowing an understanding of the devices would be the first step.
8 months not sufficient... maybe its the teacher...
There are some who just want free power and do not want to understand its operation.
Those people should just be silent and watch. Its free to watch as well !They have nothing to offer the process even if they dont believe it.
Sure! Let me run out and drop cash on several spools of wire... should it be: iron, copper, insulated, multistranded?
Let the builders know what they're building and I'm sure more people will quit bitching and start working.
In the meantime expressing your frustrations will never increase the likley hood of more information..the opposite is the case. Especially when the inventor is really tired of reading "wanna gimmeee" type stuff.
WE HAVEN'T GOT ANY INFORMATION YET!
I am pretty sure that there wont be a "home made torriodal particle accelerator"
I'll have to find the url later.... My friend in MN is actually building one.
I will not respond to anything like this again Im tired of it too.
What responce? You didn't answer or even retort... Your "responce" was nothing more then another verbal carrot on a stick. Example: "Keep talking like that and we wont share anymore information..."
Keep well , we have a lot to learn don't... you.... think?
Yes... Yes we do. I can't wait for it to actually begin.
Ok I'm going to disappear now. I'm sorry to those who are angered by my reply.
Steve Marks did not need anyone feeding him how to build this TPU so technically neither do you! What Mannix and Steve have provided; many lengthy videos, cutting open of the TPU, personal discussions and conversations, risking their pensions to help humanity.... they have done more than enough, now it is our turn. Evan
Dingus Mungus
@ fcpeace
Please check debate thread for response and or continued discusion.
