The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
dean_mcgowan
Another simple observation, and it is often good to remind ourselves of the obvious, is that the only thing that tends to improve the resulting output is scale of the device.
c0mster
Quote from: c0mster on July 10, 2006, 07:55:53 PM
I thought I would post a link to this video and image from my lab.
Tesla is right, the capacitor does make a difference in the longitudal waves down the coil from the violent blast. The better I can get the cap to charge and release creating a bigger snap the better the strobe light lights. Here is an image of the setup http://cmnet.ca/projects/maggap.jpg. Here is a video applying violent shocks to 6 raps of house wire. The right side coil is connected to the strobe light. http://cmnet.ca/projects/hvt1.avi.
CamsterÃ,  Ã, Ã,
When I test the circuit without a capacitor, the spark gap will jump the full distance of the electrodes when the electrodes are at their widest. The strobe light will not light and using a milliamp meter on a separate coil, which is held close to the base of the heavy coil, shows 0 ma. With 2 .05 microfarad 1kv cap in series from a 1940ââ,¬â,,¢s radio, the distance between the electrodes has to be about 1-2 mm to get a white spark. The strobe light lights and the amp meter shows .05 ma. As well I used a coil connected to my oscilloscope, placed at 90 deg to the setup coil and could read a 9-10 volt ac wave. I believe with this experiment I may understand what Peter Lindermann described in his presentation with regards to some of Teslaââ,¬â,,¢s work in conduction with Hertz. ââ,¬Å"Slapping the water with a hand.ââ,¬Â One other note: The positive side of the thick coil showed much less to no action but the negative side is where I took the above values. Disconnecting one wire from the strobe light, I could get a 3mm spark that would seem to go into wood, the ends of capacitorsÃ,  and the end of my finger from that wire with out any shocking affect <such fun :)>.Ã,  So perhaps the higher readings with the capacitor was do to the capacitor being a capacitor and holding back until it has some amps behind it sending more amps into the main coil and producing a higher voltage to light the strobe. ???? The pulses were timmed the same.Ã, Ã,
Camster
bob.diroto
Quoteauthor=dean_mcgowan
I still have the concern here, to draw an analogy, that capacitors resistor etc.. are digital technoloy compared to analog, in the sense that you may view a capacitor as a means to quantify the effect in a time scale that is observable and hence measurable in the four dimension of space time. ie simply varying the juncture in my simplified diagram of the two circuits would both balance the mass and frequency of the circuit and hence afford tuning of the circuit. Applying the spark gap has merrit though it also is very hard to maintain a specific qualatitive amount of energy across the gap and could be more disruptive than productive in this paradigm.
Regards,
Dean McGowan
What a load of crap.
Capacitance, inductance and resistance are present in all wires to varying degrees.
By this very fact capacitors, coils and resistors are ANALOG to suggest otherwise is tripe. DIGITAL my arse.
It is the infinite non-step like features of analog circuits that make them so suitable for the task at hand.
One of the reasons why eletron tubes would be far more suitable because they allow far more harmonics to progress around an analog circuit.
You may be able to tune your coils to a particular resonant frequency without an additional capacitor but this doesn't mean there is no capacitance in your circuit. Capacitance introduced by your choice of insulation between layers; distance apart of the turns; diameter of wire; size of coil; choice of former; tension on the wire; precision in winding etc.
It's already well understood that fast rise and fall times along with short impulse times coupled with a circuit that never allows reversal of current (diode operation) are required to generate radiant energy. It is more than clear from Tao's work and confirmation from Steven Mark that this is the direction to take.
A spark gap is a good initial choice because it has the attributes of incredibly fast rise time and fall time, and provides a high voltage diode action, and a switching action. By definition if voltage could be applied instantly to the wire the harmonics would continue on into infinity. High voltage capacitors by definition are able to present large amounts of charge to a wire via an appropriate switch.
It is precisely these very high frequency harmonics that we are after in our coil circuits as it is the interaction of these frequencies that can then be observed and deductions made on the right combination of frequencies to use to achieve the desired result.
You'll note from the comments by Lindsay Mannix that they are looking for appropriate switching mechanisms. Fast rise times are not the problem. It's the fast fall times that is the issue. MOSFETS only go to around 1500V. IGBTs go to much higher voltages but have much lower switching times because their trailing edge keeps going - the current doesn't shut off smoothly.
Like I was saying earlier your purpose here is to waste time, detract and misdirect.
gn0stik
to anyone trying to access my site, i'm changing providers and getting a full refund. sorry for being off topic, but this is the 3rd time it's been down in 3 days. I'm not staying with them. it's rediculous. All I need is a full backup out of them, when I can get back in via ftp and then I'm cancelling. rediculous.
no time to read now. later...
Gn0stik.
gn0stik
Quote from: bob.diroto on July 11, 2006, 09:03:29 AM
Regards,
Dean McGowan
Seeing as how he has dropped the negative, I kinda think we should give him a chance. After all he was asking for input on his circuit. And you did give him some which if he tried really hard could take as constructive criticism, and use your input. At least he's winding coils.
I can't say as much.. I've been too damn busy with life to get the right equipment. So there's really no use in me winding coils, as I could not measure the results anyway.
Dean does seem to be a genuine fan of free energy according to his msn profile.
Or maybe your right, perhaps he just likes messing with people's heads.
Dean? What's your motive here?
