The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 27 Guests are viewing this topic.
Hoppy
QuoteThere are some clever people posting here but I think that you should try to base your comments on your research or the research of others in order to keep it real.  Here is some research I have done based on certain authoritative sources.
I'm sure we can really make some progress by studying reports on reverse engineering of UFO's and other UFO related authoritative documents. Is it possible that Steven has been directly involved in this field??
Elvis Oswald
Quote from: bob.diroto on July 27, 2006, 10:48:29 AM
Quote from: Elvis Oswald on July 25, 2006, 12:58:54 PM
There's alot of this - http://www.overunity.com/index.php/topic,1283.0.html - that looks like it relates to the theories being talked about here.
I do not see any similarities other than there being a toroidal coil.
What parallels are you drawing between the two devices ?
For one thing - the use of an iron tip on the conical coil form.  There has been discussion here about *why* iron wire was used.  This "patent application" explains the use of the iron.
The next thing I see is that the device described at that link uses a shifting magnetic field.  Speculation here is that the Marks device uses a rotating field... hence the gyroscopic effect.
"Toroidal fields" sucking ZPE (as postulated by some) seem less likely than simply using the shifting field to create a current in a collector coil via inductance.
Also... the power input is tuned to the natural harmonics of the total device to spike the output.  This is more evidence that the same processes are at work with the Marks device - though it's obviously tuned to the power generated by the approaching magnet.
In general... what this link describes is a device that moves a magnetic field without motion and creates current.  That is certainly what Marks has developed... if not in the same configuration, it's still likely that it's the same process.
The device described at that link seems like more than bullshit to me... if only for the descriptions of how magnets really work.  The inventor is in line with Leedskalnin... and Leedskalnin provides simple experiments to prove his theories.
This device is not a duplicate of the Marks device.  But - I believe that the technology described there, may help in understanding what is happening with the Marks device.
mkt3920
Please refer to the pdf file of the Patent Application for their Solid State Energy Generator (toroid, coils, magnets) from this news release (yesterday) from Magnetic Power Inc.
http://magneticpowerinc.com/patent.html
gn0stik
Welcome back bob and tao. Long time... I haven't been posting much either, as I've been trying to get my own site up.
