Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
nievesoliveras
@all
Please. When you make a quote it is better understood if you surround the sentence like this:
Jesus
powercat
@all
communication with Tommey
1 he only answer some questions on YouTube
2 he has stated that he is not interested in joining this  Forum
3 did anyone try ringing him on the number posted on YouTube and here ?
We can only hope that he has come up with a new way of feeding back to source,
as this problem has been highlighted here and in the past many times
cat
Groundloop
@Bolt,
What will give me the highest Q factor for as coil. Is it a thick wire big air core coil or
a more compact Ferrite core coil?
@Earl,
If we skip the output capacitor bank then there is a possibility to use pulsed DC to a Ferrite impedance
matched transformer. (The output capacitor bank will then be after a diode bridge on the transformer.)
Still thinking about this.................
Stefan,
I agree. He could also put a low resistance precision shunt in series with the battery positive and just measure
the voltage over that shunt. A good old moving Iron ampere meter will also give a fairly accurate reading.
@Powercat,
If this circuit is o/u (and it seems that it is) then we can connect several identical circuits is series because
the input of the circuit is relative high impedance. At the last circuit we dump into capacitor bank and drive
a combination electric motor / generator. Another method is to tap just enough power at the output capacitor bank
so that we do not load the circuit too much. This can be done by transistor switching at the output.
I do not think it is a big problem that TR is not talking to us. He has posted all information needed in his videos and
it is easy to make good drawings based on the information in the videos. My personal goal is to try to make a looped
one battery only switch. No measurements is necessary in such a solution. If the battery charge up then bring out
the champagne.
Regards,
Groundloop.
powercat
Quote from: Groundloop on April 28, 2009, 09:19:01 AM
@Powercat,
the champagne.
Regards,
Groundloop.
@Groundloop
This seems to be a simple solution
On the electric motor / generator this is bad efficiency compared to solid-state but if it works why not.
As I have seen  problems with lead acid batteries in the past with these kind of circuits, is it possible to  use an  other capacitor bank instead.
My knowledge of electronics is limited and I have stated my position at the bottom of page 3 in this thread.
I have seen your great work on this forum before
hopefully champagne
cat
gyulasun
@Groundloop,
The best would be using a pot core to get high Q values for the some kHz range.  Pot cores of 20-30mm diameter and AL values of some thousand.  And thick wire to get the lowest copper loss possible, considering the winding volume of the pot core.  I do not think an air core coil can beat a pot core in Q values at this (audio) frequency range.   EPCOS (ex Siemens) or Philips or Neosid may be available in your country.
rgds,  Gyula
