New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
noonespecial
Quote from: Alexioco on April 17, 2009, 11:59:23 AM
Hi all, Now I could do with somone telling me where I may get some weights from, weighing 1 - 6 ounces because I need the following weights:
two of 1, 2, 3 ,4 ,5  and 6 ounce weights (for test purposes) 3 ounces with probably be the best but I want to make sure...
Edit: Once I have the weights, then all I need to do is make just one more thing and the wheel is done, I could possibly have it done for monday. Some of you here could probably build my wheel within a day :P
Thanks
Alex
Hi Alex,
Without knowing exactly how the weights will be used, you might try some bolts with combinations of washers and/or nuts for these size weights. I don't know if this fits in with your scheme or not.
Regards,
Charlie
Alexioco
Quote from: noonespecial on April 17, 2009, 01:12:17 PM
Hi Alex,
Regards,
Charlie
That, sounds like a good idea, nuts might be good for using as weights, what are the most heavy ones you can get?
Edit: I just found that in my back garden we have led, so I can cut the weights out of that... :P
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
erickdt
I'd strongly advise against messing around with lead. Lead can be extremely toxic.
No one special's suggestion to use washers is a good one.
Alexioco
Quote from: erickdt on April 17, 2009, 02:13:14 PM
Is lead safe when its just dry? or should I not mess with it at all? if so then I will use washers...
Edit: Stuff the lead, I just read a bit about it, no thank you!!!
So what weight of washers/nuts and bolts are available?
Alex
Low-Q
Quote from: erickdt on April 17, 2009, 09:30:00 AM
Of course gravity is conservative. That however does not mean it isn't capable of producing work.
That is the exactly point in conservation. Conservation means no change. No change means no work.
If gravity was dynamic, however, like it increased and reduced all the time, it would do work, but that isn't the case in real life.
So bottom line; A conservative force like gravity cannot do work, are not capable to do work, and will never do work.
Vidar
