The Perfect Spacecraft
Started by onthecuttingedge2005, June 10, 2009, 01:23:40 AM
triffid
Their power output would be in the milliwatt range not in the megawatt range.But a man named Crump got a patent claiming he could power electrical devices just by using the free radio waves hitting his antennas.I myself measured .04 volts coming from a crystal set output.Not free energy since its coming from a radio station but free to me once I had the crystal set up and running.I could get that as long as the station is powered up.My voltmeter will only measure 1/100 of a volt.Its a less than $20.00 voltmeter from radio shack.I need one better to measure 1/1000 volts.Triffid
triffid
My 25 foot coil consisted of a 25 foot extension cord which had three wires(including a ground wire).I used the ground wire as a tap wire and the other two wires acted as lakhovsky coils.It generates ac if I am to believe what I read just like an antenna can be considered as a source of ac.Triffid
Here is one concept for fusion reaction I was contemplating by levitating and oscillating a D2 Droplet in X,Y,Z coordinates at Mach Velocities to obtain a Plasma Fusion reaction state, remember that successful fusion reaction gives out 30,000,000 times more energy than the best chemical reaction known to mankind. the magnetic fields used to levitate the droplet are also used to oscillate the droplet very very fast until collision states occur producing Plasma fusion. although the actual mechanism to do this may be a bit more complex it is the right path I believe to achieving over-unity and would Idle at high energies. it might be better to incorporate
superconductive XYZ Bitter Coils to achieve High end levitation fields to help in the reaction process.
Jerry
Hi triffid.
there is a way to help out with needed energy in space and was developed by NASA, the Satellite if given a very positive outer charge will attract free electrons in space and they would collect directly onto the skin of the satellite and then collected via a capacitor for power systems, I don't think they have tried it yet but it is a viable concept that could help start smaller processes needed if say the main power system suddenly cut out and needs some secondary source of energy to get it going again. just some thoughts.
Jerry :)
the_big_m_in_ok
onthecuttingedge2005 said:
>>Hi Jerry,
Do these Patents describe what you said above?
http://www.google.com/patents?id=ENkxAAAAEBAJ&printsec=abstract&zoom=4&source=gbs_summary_r&cad=0_0#PPA1,M1
http://www.google.com/patents/about?id=IcsrAAAAEBAJ&dq=atomic+fusion+space&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100
http://www.google.com/patents/about?id=QZYCAAAAEBAJ&dq=atomic+fusion+space&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100
http://www.google.com/patents/about?id=2AoyAAAAEBAJ&dq=atomic+fusion+space&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100
Another thought occurred to me:  A Bussard ramjet with a positively charged open cone leading edge would also attract electrons.
See also for a simple, basic example:
http://en.wikipedia.org/wiki/Bussard_ramjet
--Lee
