0 Members and 158 Guests are viewing this topic.
baroutologos
I tend to believe that also Grizly...
I am thinking... assuming kapanadze is real and experiences a COP of 300+ with a setup that cannot be called rocket science... or CERN installations. A crude setup of some dirty coils and draft spark-gaps etc.
I, in order to have constantly under unity 0.2-0.5 etc efficiency, means that not only my setups are not optimized, but are not working on the principle at all. Period.
Most OU theories are just theories and in the long term, the hardware merchants or the DVD and inspirational book -BS- sellers make big bucks.
Actually - in case, I REPEAT, OU is real - it should hide in ways totally unconventional and odd and weird and unsual that we might think it is. Whoever just claims the opposite should bear the burden of proof. No proof = BS, so simple.
I am already being orieanted in more "Arcane" devices and see what's next as far my powers permit.
grizli
Quote from: baroutologos on April 01, 2010, 01:22:50 PM
Arcane ?
xenomorphlabs
Quote from: grizli on April 01, 2010, 12:32:54 PM
ALL energy in LC is reactive: all energy is equal to full capacity charge.... SO if we discharge capacitor when charged in LC resonance we use full reative(VAR) of capacitor hmm
mabe.. maybe.. like smith says
I wonder what else we could do
But Smith explains under what conditions that only can happen in his documents and this is needed for this to work (if you want to go the Smith way). It is needed though to combine different parts of his descriptions to the whole picture, because he never mentions all conditions at the same time.
Cap-Z-ro
Quote from bart...
" Thus the magnetic field influences the "unknown energy" and it is transmuted to useful electrical one? Why not to heat? And if so via what procedure? "
That calls for a quote from the master of magnetic energy(using steel by the way)
" You've got to ring the bell "
- Ed Leedskalnin
Regards...
hartiberlin
Hi baroutologos,
you have done great hardware work so far,
but did you also try to exactly sync the Teslacoil spark firing to the output LC resonance circuit ?
I guess, if you just fire the sparkgap of the Tesla Coil NOT in sync with the output
Resonance circuit, you will only see underunity output.
Also did you connect the output circuit also to ground via one line ?
I guess it really needs a good ground connection to suck
the free electrons from the ground into the circuit.
Regards, Stefan.
