verpies
Quote from: penno64 on September 16, 2012, 01:50:01 AM
May we have a little more info on the grin box ?
The difference between "grin box" and "green box" is illustrated below.
FreeEnergyInfo
Hi Antanas,
Penno
VIEV ....
www.realstrannik.ru/forum/44-freeenergylt/83288-generator-se-ot-nikoniko.html#83288
xenomorphlabs
Quote from: jbignes5 on September 15, 2012, 01:33:22 PM
In reality if we read Tesla's notes on this form of electricity you will find that it doesn't induce anything but actually is excited by the electric field. If there is a magnetic field it would only work against the generation part of this dynamic transformer. Indeed if this form of energy is static then we must apply rotational momentum to get it to supply current.
@jbignes5
You are looking at TK from the right angle IMHO.
A STRONG indicator that TK is not interested in a strong magnetic field in the core was pointed out by me a year ago here : http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg299695/#msg299695
In the aquarium device V1 he uses a brass core in his "somehow"-filar coil. Brass is commonly non-magnetic .
It even reduces the inductance @ high frequencies.
His transformers are likely to work on an electric field basis somehow as you are pointing out.
Chances are that there is no transformation going on at all between the 2 coils.
The so-called TK coil could just be a current amplifier which is exactly the effect a coil with a NEGATIVE inductance would have.
The brass core together with the CORRECT winding technique could theoretically achieve that and maybe TK has put it into action.
The "primary" coil-cap oriented upwards would just have the task to create a surrounding electric background field to enforce the right flow of positively charged to negatively charged "charge carriers".
Keep it up.
itsu
Quote from: T-1000 on September 15, 2012, 08:46:30 PM
Itsu, watsup:
Here is translation
"And now about circuit:
Thanks a lot for this info T-1000, so it means that even the creator of this device is not sure about the used wires of his coil.
Well, i finished my main coil and did some measurements/testing, including HV puls testing on the coax.
Here is the data on MY coil:
Cardboard former 5cm od
L1 690t, 0.4mm, 3.3mH, 14.5 Ohm, selfresonant (so no cap) on 2.4Mhz   (magnet wire)
L2 380t, 0.6mm, 1.5mH,  0.5 Ohm, resonance with 600nF cap on 5.071Khz (magnet wire)
L3  41t, 75 Ohm coax (tv) foam pe isolation, velocity 78%, 1 end shorted
L4  64t, stranded HV, 72uH, 0.8 Ohm, selfresonant (so no cap) on 4.8Mhz (Belden 24Kv HV cable)
Video of the testing here:  http://www.youtube.com/watch?v=utkIltw6WrU&feature=youtu.be
Great questions from d3x0r: "How about that toroid? is that a standard component from something?"
I also am looking for data on that toroid, like diameter, type/make, number of windings (4?), number of turns, wire used etc.
Anyway, parts are on order for the Main generator and for the pulser, it will take a while for them to arrive.
Regards Itsu
jbignes5
Quote from: xenomorphlabs on September 16, 2012, 06:22:29 AM
@jbignes5
Keep it up.
Yeah I have to agree that his coils do not have a core of anything that reats to magnetic fields. If you look at most of the videos you will see brass as a rigid metallic core. I'm thinking he wants metallic core because of the electric field and not magnetic. In the electric field two metals show incredible effects. Aluminum is very explosive and tends to amplify the electric portion and copper gets so agitated that it will melt if the stimulated charges do not get taken off. This agitation can be likened to AC. This has never been so prominent in experiments except for the Slayer Exciter. I have seen ranges of 20-25 feet away from the exciter that leds will light up brightly with the proper diode half bridge Commonly called an Avramenko plug attached to each led leg.
As to weather there is a positive charge or negative that remains to be seen. In my honest opinion there is only one charge. There is a balance point that makes it positive or negative when compared to the background charge levels. So lets say a charge has a balanced charge that equals the background. This would make the charge neutral. But add charge to the charge and it becomes positive. Take away charge and it becomes negative but it is always positive charge. It just appears to be negative when compared to the background. You could think of it like the surface of water. Scoop out some water and it has a divit for a split second then balances to the main body. Drip some water in and it has a bulge for a split second but again balances out to the background surface. But it is always water. That is not the best analogy but it is the closest I can think of.
What I really think TK is doing is only using the thick copper as a radiator of the electric field. The gap is only there to allow a build up of this electric field before it discharges and allows the field to flow around the heavy copper coil. Just like in many other experiments with extremely high voltages corona discharges illuminate the paths of this electric field and we get to see the pathways of that electric field. These fields are always present even if we can not see them through that illumination of the higher voltages. The spark we see is actually charges accelerated along the pathway to light speeds. This causes the illumination. This accelerating does not stop at light speeds either because if light is to know where to travel something must have made a connection way before light moves or in this case charges. I hope that is understandable.
The premise behind TK's device is to stimulate the drive coil into agitation by the use of the electric field that surrounds the drive coil. When the drive coil is agitated it acts very much like AC. The high part of the agitation being the high part of the AC signal and the Bemf being the lower half of the AC signal. Half of the AC wave form is supplied by the Bemf. I bet if someone was to scope the device it would show a sudo ac wave(deformed). Of course light bulbs don't show wave forms and pretty much will work with and deformation of the AC signal.
