0 Members and 318 Guests are viewing this topic.
xenomorphlabs
If that was that simple then you would get Kilowatts of power by simply wrapping a coil around a plasma globe or any spark gap.
There is tons of open source experiments with plasma globes and none was seeing overunity or at least has not been able to trap it into
a conductor to make use of it.
pix
Quote from: xenomorphlabs on December 02, 2012, 09:14:55 AM
Wrapping not a coil, but CT.
Regards,
Pix
verpies
Quote from: Zeitmaschine on December 01, 2012, 10:25:16 PM
the positive high voltage peak will attract electrons from ground whereas the negative high voltage peak should return the electrons to the ground.
But electrons are not energy. Electric charge is not energy.
This is also what I tried to explain about the Kornelson's transformer principle.
So isn't this in essence that what the TK device does? Namely make electrons oscillate in a ground connection?
I have no idea what TK's device does.  I didn't even see a single oscillogram or energy measurement from it.
Looks quite complicated. What would Tesla say to MOSFET, IGBT, GaAs BJT, DSR diodes etc. ?? ::)
Any detailed explanation looks complicated at first sight.
Ancient scientists had only spark gaps and mechanical switches and saturable magnetics as active elements.  They were slow.
Vacuum tubes were an improvement, later.
Apropos: The page count is 60 and still no working Dally replica? How could this be?
That's just a result of meticulous experimenting.  That ratio of experiment to conjecture in that thread is much higher than in this one.
verpies
Quote from: xenomorphlabs on December 01, 2012, 11:44:38 AM
So you are saying that you attribute the fact that a TV flyback outputs high voltage to the slope of the signal rather than to the high winding ratio ?
Yes, "TV Flyback" is not a true transformer, therefore its turn ratio does not apply.
The currents in primary and secondary of the "TV Flyback" do not flow at the same time as in a true transformer.
The "TV Flyback" works in a unipolar mode and the diode in series with the secondary winding prevents any flow of current in this winding, while current increases in the primary.
Without the diode at the secondary, the "TV flyback" works as an ordinary loosely-coupled transformer and turn ratio applies, but this device does not work in that mode in TV sets.
xenomorphlabs
Quote from: verpies on December 02, 2012, 10:16:26 AM
The "TV Flyback" works in a unipolar mode and the diode in series with the secondary winding prevents the flow of any current in it, when the current increases in the primary.
I was thinking of the old-style TV transformers, but you are right the more modern ones do contain rectifiers.
