0 Members and 112 Guests are viewing this topic.
Farmhand
Quote from: captainkt on March 21, 2013, 07:44:00 AM
@guyuslan, this is fake the coil contains quite big batteries,someone posted a vid showing the parts dismantled. I still do not understand why people do this.
Keith
Yes, I second that I have seen the video as well, the large coil former contains a small 220- 230- or 240v inverter and some batteries.
The tell should be that the output voltage is 226 volts. The 9 volt battery is likely to switch a relay on which is the switch to complete
the LV supply circuit for the inverter, the 100 mA of current from the 9 volt battery is likely the current through the relay coil.
All of these setups where a small low capacity battery starts the device are most likely just showing the low capacity battery powering a switch
which energizes the circuit.
I use a 12 volt battery and a relay to turn on my Tesla coil by switching the mains neutral line with the relay, I use a push button switch so it a
kind of dead mans switch, if I let the button go the device stops, but I could leave out the micro switch and just power on the relay by connecting the battery to it.
In the video in question we can even see the stuff hidden inside the coil former.
elementSix
This is a little part from that Russian Patent.  The Link is at the bottom..
KEY refers to a Pulsar of some sort.
The device in Figure 5 contains an electric generator 9, set in the vicinity of the energy converter of the electric field 2. Electrostatic generator 9 is designed as a resonant Tesla transformer 22 with a high-voltage diode 23 at the output of high-voltage winding 24. The primary winding 25 Tesla transformer 22 is connected through the vessel 26 with a key 27 and with the sun an energy source 10, which consists of a solar photovoltaic module 28, a diode 29, 30 and battery charge control unit 31. Electric generator 9 is connected to the cylindrical screen 32 of a conductive material, within which no direct contact established symmetrical transducer 2.
On the inner surface of the cylindrical screen 32 over its entire surface mounted needle 33, directed radially to the axis of the cylinder 32. Converter 2 is connected to ground 11 through a drive 4 and 5 with the key through the restrictive choke 34. Key 5 is connected in parallel to a serial resonance circuit 6, consisting of a bag of 35 and 36 high-voltage winding down resonance transformer 7. Low voltage winding 37 step-down transformer with a capacity of 38 7 forms a series resonant circuit 39, tuned to the resonant frequency of the tank circuit 6 in the high-voltage winding 36 step-down transformer 7. The output of the resonant circuit 39 through a rectifier 40 and the inverter 41 is connected to an electrical load 8.
The device is the use of atmospheric electricity is as follows. Atmospheric electricity is removed receiver 1, accumulated capacitor 4, and then, when it reaches a certain value, the switch 5 is closed and the capacitor is discharged to four input coil resonance transformer 7. Capacitor 15 and the input coil 16 creates a parallel resonant circuit. Lowering the resonant transformer winding 37 is connected to the load 8. Q load lowers the input circuit and the voltage fluctuations is reduced. Thus the key 5 opens.
Next condenser 4 again accumulates charge coming from receiver 1, and when the voltage across it reaches a certain value, the key 5 again closed and the process repeats.
The capacitor 4 is chosen such that the frequency of the key positives match the frequency of the input resonant circuit.
If the energy of atmospheric electricity is one in which the frequency of operations exceeds the frequency of the input circuit is closed and the switch 13 connects the capacitor 14. The energy injected into the circuit increases.
In another embodiment, the key is installed between the primary winding of the transformer and down the land, it allows the use of electronic keys and simplifies management.
Output voltage for electrical circuits in Figure 1, 2, 3 is a sinusoid with a throbbing resonance frequency LC circuit 4, 5, and requires the output rectifier with a filter.
4 is a key element of the reactor 18 and filter 19 are connected in series with the load 8. Duty cycle converter consists of two phases: phase of energy pumping and discharge phase of the load. Take a closer look.
Phase 1 - the pumping energy. This phase takes place over time and t. The key element is closed and energized i n, which flows from the charged capacitor 4 to 8 load through the throttle 19, which at this time there is an accumulation of energy. At the same time, capacitor 20 is recharged.
Phase 2 - digit. At the end of phase 1 is the key opening 18, the current i n, supported inductive element is self-induced emf and current discharge coil 19 passes through the diode 21 to the load 8. After a certain period of time t n key closes again and the process repeats. As a result of this scheme is the output voltage of the DC voltage with low ripple. From this voltage can be supplied all conditions.
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.freepatent.ru%2Fpatents%2F2414106
x_name41
equivalent of the ground are supercapacitors on 2,7V/100-2000Farads, low voltage is not a problem because they are used primarily as a low potential and high current source just like grounding. in this case Nikola Tesla's method very reminiscent to the energy source of extraterrestrial ships because resonance as the energy source (reactive power) is transmitted via one wire (in a open circuit) to the load (by one way or another) that is connected to a supercapacitor (ground) :) I think that this technology can be used as an energy source for EV Tesla model S!
Farmhand
Quote from: elementSix on March 21, 2013, 07:56:48 PM
Interesting patent indeed, it looks as though it is a Tesla Radiant energy receiver with the method to negatively charge the plate (sphere) included as well as the output transformation to load modernized.
Seems to make some sense to me as Tesla does say his device works better if the plate is negatively charged, page 1 line 11 to 18 of these patents.
http://www.google.com/patents?id=YitoAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
http://www.google.com/patents?id=YytoAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
So I think he would have covered the concept of the plate being negatively influenced, but not really how.
Anyone else interested to try it ?
Cheers
Hoppy
Quote from: Farmhand on March 21, 2013, 06:12:31 PM
Agreed.
