0 Members and 167 Guests are viewing this topic.
T-1000
It is understandable with motors just what about generator case and when this is directly affected in conjunction with same  motor?
TheCell
According to Hector a induction motor can be used as generator, with an initial magnetic field from outside or an initial current. Maybe the two alter the roles.
verpies
Quote from: bbem on July 10, 2013, 08:31:31 AM
How is this different from the WITTS video?
Two motors driven via a common shaft are very different because they have their stator cores far apart, thus they do not influence each other magnetically.
Shorted loops of thick copper wire (e.g.1 turn windings) joining both stator cores would increase or bring back this influence into the picture.
You can see two such soldered conductor loops joining two stator cores, when they are not far apart (marked by yellow arrows).
T-1000
Quote from: verpies on July 10, 2013, 08:39:03 AM
It is very different because two motors driven via a common shaft, have their stator cores far apart, thus they do not influence each other magnetically.
On begining of second minute in video they are joined together there. so there is magnetic influence.. :)
And man, this been a while in WITTS video from last year, any more sucessful replications?
As far as I understand the other magnetic field on second frequency is introduced by shorted coil then you have both frequencies in sync so you have required condition to make things happen.
