0 Members and 113 Guests are viewing this topic.
zcsaba77
Quote from: verpies on July 10, 2013, 08:39:03 AM
Two motors driven via a common shaft are very different because they have their stator cores far apart, thus they do not influence each other magnetically.
Shorted loops of thick copper wire (e.g.1 turn windings) joining both stator cores would increase or bring back this influence into the picture.
You can see two such soldered conductor loops joining two stator cores, when they are not far apart (marked by yellow arrows).
Hi
Whats happennig if beetween motors is gap (example 1-2cm), I mean can not goes magnetic flux goes by core contact, it will run without any problem, or not?
ps.: if I good understood shading pole/coils makes start directed motion which direction must go  ::)
zcsaba77
Quote from: TheCell on July 10, 2013, 08:12:12 AM
Have you never seen this type of motor in washing machine pumps , older turntables, ventilators. It generates the 2nd phase by this shorting wires. Normally a run cap is used for that in induction motor, or whats called a asynchron motor. This type of motor is an asynchron motor, but without run cap.
its look like MWO cooling fan motor, probably that guy stole from factory  ;D
Grumage
Dear All.
I may have the answer to the enigma that dear Wesley threw at us the other day.
I, like I would think many of us have, is a vast array of microwave oven parts!! So I had a quick look at the scheme. I simpy direct coupled the two shafts with a piece of sleeving. Like Hoppy I was really sceptical that a couple of "shaded pole motors" would do anything. But hey, I had some time. When spun by hand they generated about 0.1 V ac and showed nothing on the scope.
How to de bunk?? Easy!! Using a microwave oven transformer that I had milled the weld from to seperate the windings. I placed this in close proximity to one of the motors and Presto, it ran even without a kick start. So, to conclude, I think that there is a directed alternating EM field not too far away, but far enough so that a kick is needed. I think there would also be sufficent induction to light a bulb as well.
Finally I also thought that if the footage was from different sources, how come the light bulb was the very same? Even down to the insulation tape!! :)
Cheers to all, Grum.
stivep
Grum and  rest of you my friends thank you  very  much
Verpies do not forget to respond to my posts regards Colman investigation and supporting material that I posted.
thank you for your work as well
Wesley
PS:It is not yet end of the story with  motors
http://www.youtube.com/watch?v=vCbZ3CRWx7I
http://www.youtube.com/watch?v=t6l7kw-W6jI
http://alexfrolov.narod.ru/
Thanks to
Arunas:
we have responder  Russian professor  Фролов Александр Владимирович - Alexander V. Frolov
And this guy is  brain by itself
I found this:
but You have seen it anyhow it is old stuff.
http://www.youtube.com/watch?v=FlPWy6z9Gig
http://www.youtube.com/watch?v=-Ztt3R4Bu_0
and this but little to controversial:
http://www.youtube.com/watch?v=R9i8_CFZtfo
That is  what NYW Group is for and is about simply uncorruptible
http://en.wiktionary.org/wiki/uncorruptable
uncorruptable (comparative more uncorruptable, superlative most uncorruptable)Alternative form of uncorruptible.
http://jnaudin.free.fr/dlenz/heinseffecten.htm
dllabarre
Quote from: stivep on July 10, 2013, 05:03:11 PM
Wesley
Can you email guy in China and determine if he is using MOT transformer or any HV HF transformer near motors?
I don't believe he is but please ask him.
Thanks
DonL
