0 Members and 274 Guests are viewing this topic.
stivep
Quote from: Zeitmaschine on December 19, 2013, 04:00:24 PM
Isn't the high voltage input of C1 in essence the same like receiving a radio signal? The radio wave coming from the AM radio transmitter is a high frequency wave modulated by an audio signal. Medium wave is 535kHz to 1705kHz, the modulating signal is audio frequency up to 8KHz.
Here the high voltage frequency is around 100KHz (up to 300KHz), its modulation frequency is 50Hz. So if a crystal radio can boost the energy coming from the radio transmitter, then it should be possible to boost also the energy coming from the high voltage generator.
Also worth a try: C1 in 50Hz resonance with L1 and C2 in 100KHz resonance with L1.
And I think, so far this is as close as we can get to the principle of work of the (simple-to-laugh) Tariel Kapanadze device. Just the working replication is still missing.
QuoteWesley's: you need to read my post again I just finished that  sentence( I was interrupted  :)  )
the basic concept of Lithuania experiment  was 1.2MHz modulating carrier  that is 50Hz
so here 50 Hz is the carrier  and modulating signal is higher in frequency ( snake like shape)
And yes crystal detector in radio receiver   takes its energy from energy of radio wave.
Energy must come from somewhere .
( also in my post above, I touched  the subject of  pump, or electrostatic pump)
Wesley
More laboratory  tools for Colman  experiment
the last two pictures are from  low energy backscattering 8 horn style photomultipliers for  x-ray imaging as prove  that device works that would be out of question
Zeitmaschine
Quote from: stivep on December 19, 2013, 06:53:42 PM
Small correction: Crystal radio takes its excitation from radio wave, but energy comes from Earth's electric field.
I would say, to me this arrangement looks like a self-exciting crystal radio circuit. The oscillator T1 performs the function of the radio waves but with additional synchronization due to C1.
verpies
Quote from: d3x0r on December 19, 2013, 01:41:18 PM
Researchers have successfully used light to transfer data through fiber optics cables. By using twisted light, they were able to transfer 1.6 terabits per second.
Yes, this is a fascinating field of research.  Circularly polarized light can actually impart a twisting force to matter, which normal light cannot do.
Also, many modern 3D movie glasses use circular polarizers to make them immune to head tilting - a problem which affects the older linearly polarized glasses.
You should find this video about fiberoptic data transmission techniques, interesting.
d3x0r
Quote from: verpies on December 20, 2013, 12:17:05 AM
(Fixed link) you had an extra overunity.com in there...
But in radio signals travel further clearer; in astronomy you can see planets usually obscured by the star's light...
verpies
Quote from: d3x0r on December 20, 2013, 01:26:23 AM
I pasted the correct link but www.overunity.com added itself in front of it without my knowledge.  Probably some kind of advertizing gimmick.
You did more than remove the unwanted "www.overunity.com/" prefix.  You also changed the rest of the URL without realizing that youtube.com interprets arguments after the slash and question mark differently from youtu.be ...or not at all.
I can't
