0 Members and 195 Guests are viewing this topic.
cosmoLV
Since i'm not welcome in Energetic Forum i try to fix some missunderstandings with FE and Tesla coil and D.L. Smith
What is wrong with smith? Smith changed one thing:
See image by Link: http://img651.imageshack.us/img651/8216/voltampwinding.png
Thing 1.) coil need to be on ferite rod core
Thing 2.) There are no Volts and no Ampers - change the words (Volts, Ampers by Domain 1 & Domain2)
And read This one: http://translate.google.com/translate?hl=en&sl=ru&u=http://www.krugosvet.ru/enc/nauka_i_tehnika/fizika/MAGNITI_I_MAGNITNIE_SVOSTVA_VESHCHESTVA.html&ei=32okTLHYD5eHOO6ehNYC&sa=X&oi=translate&ct=result&resnum=1&ved=0CBYQ7gEwAA&prev=/search%3Fq%3Dhttp://www.krugosvet.ru/enc/nauka_i_tehnika/fizika/MAGNITI_I_MAGNITNIE_SVOSTVA_VESHCHESTVA.html%26hl%3Den%26sa%3DG
Keep your chakras opened :)
baroutologos
@ Cosmo,
Amusing. Change coil instead of air core to ferrite core, instead of volts/amps to domain1/domain2... what are we supposed to do here? Decryption about what the old Smith could have really, really meant?
Personally, i take his teachings as he wrote them down, and without doubt i can say they are BS (widely tested)
Regarding your part,
I personally hate to see people claiming they "know" and try to eduate all us with links full of theories, oppinions etc.
We are here as seekers of the truth, not as conspirators intended to overthrow enstablishment theories with our OWN.
Pls, get useful
cosmoLV
Quote from: baroutologos on June 25, 2010, 04:54:16 AM
@ Cosmo,
Pls, get useful
i hate too :) but, this is not how it looks. i'm seeker too - i'm not claiming i know everything, i know only facts from my experience and experiments - and this document on the link explain strong magnetic fields in ferite core.
if you see Tariel's video - you can hear, he says - "Magnetic field resonate to " - but he dont know about fact, there are no resonanse, but Domains Relaxation
by that... you see - Don smith shows schematics, coils and no free energy device - if you see that Don Smith simposium where he shows this one device running and stressed about that guy who measure voltage - in one word, Smith not telling something and by Psihology, since i'm study Psihology about all my life and University, see Don Smith hands goes above his head - He laying.
Tariel not showing schematics, nothing...
and question is - do you believe Smith or tariel who show real deal ;)
exnihiloest
My last tests:
I put a 15 ohms resistance in series between the light bulbs and the earth, in order to visualize the output current (2 probes on each pin of the resistance, oscilloscope in differential mode). It is a half-rectified sin wave (see the photo). At the moment of the photo, the variac was outputing only 50v.
There is still HF currents but surprisingly, far less than on the MOT primary.
I monitored the radio frequencies from 100 Khz up to 400 Mhz. There is a very strong HF noise all over the band, especially under 50 Mhz. The level changes a bit depending on the frequencies but not much. I think that all spark gaps generate such HF noise.
Finally I have removed my 2 ground connections and replace them by a short cut to close the circuit. It makes no difference. Until now what I observe is perfectly according to the laws of electronics engineering.
baroutologos
@ exnihiloest,
Nice scope views. That i call a methodology followed!
By the way this has its logic, since in the first place you got no OU (or an OU appearance) then all are going according the EE teachings.
I wander why Naudin that has some sophisticated outfit, he does not uses any.. too early?
