core
Quote from: T-1000 on October 02, 2011, 11:11:04 AM
Then build one, if you follow exact N. Tesla steps, the 99% of success chance is yours :) Only after you can have own opinion on what's really going on.
Dude what part of 'others have tried and failed' did you not understand. BTW what does a Tesla coil have to do with a Caduceus coil?
To make those coils arcing on top (clearly seen in videos) what do you need to have in boxes? Again, the answer will come after you spend time actually replicating at least known things... ;)
P.S. TK did not invented everything in his device, he only made "resonance in resonance" synchronization in his devices.
Um....... you are aware that the long spark in the 100Kw unit was for show right? the actual operation of the unit is with a wire connecting both coils. this has already been stated 1,000 times.
-Core
T-1000
Quote from: core on October 02, 2011, 11:28:06 AM
Do research what counter-bifiler and Caduceus coils are for :) In result you will see no difference for using them in Tesla Coil.
It's not, The capacitors must discharge in less than 100uS so then you can extract most energy from them.. Plus the receiving coils (bobinas in center) are tunned to same frequency as transmitter coils (used instead of antenna).
Study http://www.teslauniverse.com/nikola-tesla-patents-649,621-transmission-of-energy and http://www.google.com/patents?vid=685957
Good luck :)
core
Quote from: T-1000 on October 02, 2011, 11:38:10 AM
If there's no difference as you say then why use them? Why go through the trouble of winding one when there is no difference?
Good luck :)
Who is discharging at 100us and has data to suggest this other then there opinion? Basically just re-hashed internet theory.
If its as simple as that Tesla patent why don't you, or anyone, have free energy yet? And the patent speaks nothing of Caduceus and counter Bifilar.
-Core
T-1000
Quote from: core on October 02, 2011, 12:34:43 PM
-Core
I did built small Tesla coil at home, tried counter-bifiler and Caduceus windings as Tesla primary. With Caducious you expect 2 secondaries on its ends..
The ion flow made end of secondary coil glov and my hands won't hurt when catching 1cm+ spark from it. From single wire it even lights up 220V 15W bulb partially and luminescence lamps start glowing up nearby. The energy amount I see over there is way much more than I feed into HV circuit from battery.
Obviously you got only theoretical part so it can't be much understanding about what's happening in Tesla coil and I strongly recommend to get practical knowledge before discussing further.
FreeEnergyInfo
What is common in these pictures?
That's right. Tesla coil is placed between the plates in a capacitor.
At this Konder received pulses as in the type of cathode ray tubes. It creates an electrostatic field. Tesla on this occasion said that if you miss the essential disturbance through such a field is formed, what's ... :)
I do not remember who said in an aquarium but also wound coil to the condenser .....
ЧÑ,о общего на эÑ,иÑ... снимкаÑ...?
Правильно. КаÑ,ушка Ñ,еслы помещаеÑ,ся между обкладками как в конденсаÑ,оре.
На эÑ,оÑ, кондер посÑ,упаюÑ, импульсы по Ñ,ипу как в газоразрядныÑ... лампаÑ.... СоздаеÑ,ся элекÑ,росÑ,аÑ,ическое поле. Тесла по эÑ,ому поводу говорил чÑ,о если пропусÑ,иÑ,ÑŒ эÑ,,ирные возмущение через Ñ,акое поле Ñ,о чего Ñ,ам образуеÑ,ся... :)
Не помню кÑ,о говорил но в аквариуме индукÑ,ор Ñ,оже намоÑ,ан на конденсаÑ,оре .....
