0 Members and 70 Guests are viewing this topic.
energia9
if i understand correctly,
If we are clever enough,  we could shake atoms of copper and derive energy from it. this way we would not need ferrite.  i understand that magnetic and diamagnetic materials are different, but they all have a point where they vibrate internally.   there was a french guy who could make about 40 watts of power from 1 watts input,  he fed oscillations to a coil  and then polarized a copper rod underneath it with a diode and put a resistor across the positive terminal of the battery and the diode which leads to the copper rod,  i see that this is quite serious..
So aidas and arunas,   if the device runs,  and you want to take out the ferrite when it runs, as you take it out, lamp gets dim and eventually gets no power at all really,   right??
Thank you
T-1000
Quote from: energia9 on October 27, 2011, 06:46:59 PM
Thank you
You might try do same to air core Tesla coil but it would not be so easy.. :)
We are ringing ferrite then hammering it explosively with HV capacitor discharge on right time for standing shockwave so without ferrite core the resonant frequencies would change as air coil ring has different resonance and not so easy way for what we're doing.
dllabarre
Quote from: T-1000 on October 27, 2011, 07:09:39 PM
Wesley, T-1000, Aidas
I thought this team was duplicating Tariels device?
Tariel didn't use ferrite core in his coil on the Green Box device and he got 22amps on the ground wire going to the bulbs (load).
I don't understand?  ???
DonL
T-1000
Quote from: dllabarre on October 27, 2011, 08:18:24 PM
DonL
Not exactly, we are going on own way with reinventing Nicola Tesla wheel. Obviously most principles match on what you see in TK devices.
