New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
markdansie
Hi Ali,
Thanks for posting what you did to Stepan (I already had read that)
I have found over many years that my role is to ask the obvious dumb questions. Often understanding is burried in simplicity.
I guess the key is as you stated you are increasing voltage but reducing current. So is the overall energy available on your output is the same? Ie 30 volts at 7.3 amps say (220 watts) vs say 220 volts at 1amp (220 watts). Am I missing something here?
So is it possible at this stage to explain the increase in overall energy if what I stated above is not correct. If you syphon something you are just moving it from one place to another but not adding to it as you do
Mark
winsonali
hi mark,
"you are increasing voltage but reducing current"
REPLY:always remember you can provide voltage to some load but the current is defined by the load it self
explaining further: in a 220 volt socket you can plug 1000 watt heater it will draw 4 to 5 amps
at the same time if you put 100 watt bulb it will draw 0.5 amps approx.
so voltage is provided , current is the drawn from the line according to the load.
in watt meter voltage coil only open the path for magnetic flux but current coil make the movement to see how much wattage is being consummed.
in my device i am providing it 30 volts
when we conduct a test of 160 watt  at output source of our device it was giving us 220 volts at 0.7 amps approx.
and when we check the current at the input the voltages are 30 volts at 1.5 amps
RESULTS:
input  =     30 *1.5 = 45 watt  (in a simple approach not going in complexity at the moment)
output = 220 * 0.7 = 154 watt (you see amps gone down from 1.5 to 0.7 this is very natural)
Now with in the device the switching is in a very specific way, causes a resonance and more charges aligning themselves then in a conventional manner
telling you truly when i was conducting these tests i was knowing that charges are there but they are not in flow and i have to find a way to make them flow or convert them as workable PD(potential difference )
mechanical example of situation: you have bath tub full of water the top is open water cannot flow out from top  if you make a whole in bottom of the tub it will flow (natural) now i have to make water flow from top. if i can do the same in electronic means what i have achieved is creating PD with non aligned electrons.
i am in the middle of writing the thesis about my theories and there practical conversions so i will not discuss these concepts any further until i arrange to publish them
i am not saying that i am a very intelligent man but i am learning as well an argument for  argument will waste our own time rather then a simple practical output if my device is working and have potential soon it will be there in market its just a matter of time
i think my idea to givel the unit for R@D purpose to get hold of some funds as donation to noble cause to further carry out research was not a good idea
coz according to my professional ethics i will not give unit to any one until he is satisfied and knows what he is getting
and people around me are not able to digest the new concept here, i should carry on my work and take it to a completion level
strange enough no body asked me ,what is the next level in development if its working why not i start producing it
the difficulties;
the behavior of the unit is purely like a generator you off load it, the  voltage rises we need to develop an AVR
loads like air conditioners turns on the compressor and turns off this could seriously effect the process, an instantaneous response to load variation is required to be incorporated with in device
device cannot work without load it will destroy it self (resonating frequency) we need to include dummy load to balance the device and harness the appropriate output according to current dissipation.
if output load increase from the capacity of input source the unit destroy it self
things are not so simple as it seems, a lot more work is required before the device is ready for market
i posted the video on you tube when i saw magna coaster video, i did wrong i should complete the device by burning more of my own fuel to reach the destination , rather then giving people half cooked device i think i should get hold of some project to make enough money to complete my unit then sky is the limit.
thanks to everyone
Ali
markdansie
@ Ali,
thank you for your patience and explanation.
what time is a good time to phone in GMT time. If you are in England at the moment you are either up very early or very late.
Kind Regards
Mark
robbie47
Hi Ali,
Thanks for all this information and sorry to ask you even more questions. This is too fascinating to only watch and read  ;)
I have following questions for you so we all can better understand what your circuit and software actually does:
- What is the range of the switching frequency of your circuit?
- You mentioned in your video that no transformer or coil is used in your circuit. How can you obtain resonance even if you apply a pure resistor load like a light bulb? Does the coil of the Wattmeter play a role too?
exnihiloest
Quote from: winsonali on September 01, 2009, 01:23:58 AM
i am not saying that i am a very intelligent man but i am learning as well an argument for  argument will waste our own time...
Hi Ali,
Then why have you rendered public your experiment?
As in such claims of extroardinary results, the usual problem are measurement errors (if not a scam), imho the first thing to do before writing the theory is to let duplicate the experiment by others to confirm the results. This implies to release a accurate schematics that any electronics engineer could use. It would avoid wasting of time in blah.
