Romanian SECRET Technology which WORKED ! Lots of OU.
Started by spacetrax, September 20, 2009, 05:11:09 AM
Lucian Stefan
Dear "EMdevices" (or "Paul" maybe...),
First of all, as miscellaneous, I would like to mention that my predecessors (for instance grandfather and his cousin) had high positions within the Communist regime, even in the office of President Nicolae Ceusescu.
I know very well what did Nicolae Moraru in secret and public regime and I possess full documentation of all his research activity. Indeed, the Directia a IV-a a Securitatii Statului (in fact Serviciul de Contraspionaj) seized all the documentation and the demonstration models made by Moraru and his team of research-engineers. That is why these documents can not be found in public data bases, not even at the National Office for Inventions and Trademarks Patents in Bucharest.
I do not have special relationship to the Patent Office in Bucharest,- their databases do not contain nothing special, all that is truly special is in other databases.
On your comments about the patent posted here :
- I haven’t said that it would be the"pure magnetic energy engine" but I’ve said that is just a improved model of the classic electric motor;  improved enough to deserve being posted to the OverUnity;
- on your comments about the engine performance, you are wrong.
Because in the First of October my vacation ends, I will have no time for discussion . Please do not ask for my intervention anymore.
Each is free to believe what he want to believe and to comment as he considers appropriate, but it need not to announce me about that ...
Thank you for understanding. I wish you success.
LCS
EMdevices
@ Lucian,
I sent you a personal message.
Also, I want to comment on this paragraphs:
QuoteOn your comments about the patent posted here :
Yes I agree, it deserves posting on overunity.com, please don't take offense.  In addition,  I want to ask why I am wrong about the engine performance.  I was mainly stating what somebody translated for me from the patent.  It doesn't say what the performance is specificaly.
Can you tell us exactly what this performance is, or should be?
EM
Lucian Stefan
Seems to be something simple, almost rudimentary. Seems to be a step-by-step engine or somethimg like a variable reluctance engine- but in fact is neither one nor the other... In fact, the patent does nothing more than to describe a certain PRINCIPLE. That is THE ONLY public patent of Moraru engines.
The invention relates to a rotary electric motor, powered by electric continuous current taken supplied by electrical batteries, or by converting from the current of public networks and industrial power supply. This type of engine, original, can be used in all activities which is currently used in conventional engines known, DC or AC. They are known electric rotary machines (engines) and DC, AC single phase and triphasic, the development of mechanical work being made by the rotor winding with electrical conductors, generally the copper winding ends being welded to the collector on that slides the carbon brushes to transmit electric current for winding, to create magnetic field on rotor. The purpose of the invention consists in simplifying the industrial manufacture, reducing raw material consumption and workmanship, complete removal of the winding on rotor, also eliminates the collector and slide system, and achieve significant savings in energy consumption, to use these machines in industrial and domestic activities.
Electric rotary machines, according to the invention, remove the rotor windings, collector and system slide which is a substantial economic disadvantage to the industrial production of electric motors today.
DC electric rotary machines, according to the invention, removes the disadvantages mentioned in that it is provided with external electromagnets fixed to the casing-state and internal electromagnetic fixed to the yoke which make the closing of magnetic flux lines. Between the exterior and interior electromagnets are the magnetized ring conductors that replace electric conductors. Magnetic conductors are made of siliceous material or ferrous magnetic material. Electromagnets interior and exterior are excited using excitation coils made by winding on the pole pieces, the coils being supplied with DC electricity taken from a battery or from AC public poer supply line and converted in DC.
By applying the invention, are obtained following advantages:
-simplify construction by reducing the time of manufacture;
-economy by replacing the copper winding of the rotor and the collector,
-creates the condition for use in explosive gas environment, by eliminating the collector and slide system ,
-the reduced consumption of electricity, because the concept of using magnetic conductors and the electric conductors being substituted in the sense that in the calculation of new types of electric cars, according to the invention, no longer uses the formula that shows that power in watts is equal to the intensity multiplied by the voltage, this formula being replaced by the notion that driving force is based on electro-magnetic induction created by lines of magnetic flux applied to the polar surface.
It still gives an example of realization of the invention, in connection with Figures 1 and 2 that represent:
- Figure 1, longitudinal section through the entire assembly,
- Figure 2, which defines cross-sections of the R, S and T modules being offset each over at 120 degrees.
Electric rotary machines of continous current without collector, according to the invention, consists of three modules marked with letters R. S and T, each module is composed of two halves in the form of semi-disc, mechanically coupled between them, having excitation coils connected in series, parallel or mixed, by considerations.
Pole pieces are offset each other at 120 degrees, each of the three spinning rotors is rotating between magnetic fields of attraction and repulsion flows created by modules R, S and T. The continous current rotating electrical machine according to the invention, is composed of shell 1 which supports the entire assembly consisting of outer pole pieces 2, on which is the excitation winding 3, 4 is the yoke for closing lines of magnetic flux between pole pieces 2 and  inner polar pieces 5, excited by the coil 6. Shields 7 to 8 and bushes camps 9 form systems of protection and sliding for the shaft 10, on which are fixed the rotors 11 which will support the magnetic conductors 12, causing hardening of the rotor through the nuts 13 and spacers 14, the caps 15 slipped protecting system.
EMdevices
Here is a professional translation of the Moraru motor patent.
I hope you all are grateful for the time I spent in formatting it so it looks nice.
EM
http://www.overunity.com/index.php?action=downloads;sa=view;down=343
rotaryfcg
Quote from: EMdevices on September 29, 2009, 12:57:18 PM
He also told me about the so called "geophysical" weapon you mentioned,   the whole Romanian country talked about that weapon and bragged about it, and as a result this story became embellished and developed into something belonging to SciFi, but in reality it was nothing more then anti-tank missiles obtained from the Nazi's, (with some improvements by the Romanians, I'm sure) and they only shot at 4 or 5 Russian tanks and completely melted them, since these were armor piercing missiles with a high caloric content that melted the armor steel from the inside out.  (possible phosphor and magnesium added to the warhead payload, my guess)  These frightened the Russians who did not expect any resistance from the Romanians and abandoned their plans of invasion.
that weapon you mention here was a hydrogen-fluoride high impulse laser and by the way the first hydrogen-chloride impulse laser was developed by Coanda.The Russians were frightened because just 3 mobile laser units with one mobile power generating unit were capable to hold a tank division.don't ask how do i know this, take it for granted ... or not, but it's real.
