Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
giantkiller
@wattsup,
I see what you say here. I can add and add and add. Your last pic that shows the shorter and shorter coils is the Dollard, evgray, Tesla multipactor. As in multiple compaction at the Bloch wall section.
Also I can connect the 3 separate  iron cores in a mobius / vortext spiral. The combinations are numerous. I can add iron jumpers to close the iron rings.
The red primary is bollo-ed with that nylon connector. I can shift the primary along the circumference.
I will use this build as a base and add the overlay necessary coils.
It's small and fits on the work bench. That is a primary concern of mine. If the coils are as big as a drain pipe or manhole cover that draws negative attention from the unknowledgable. 'Big is bad' syndrome.
So for you guys reading this, here is the household political engineering: Keep the devices small and go to bed on time to reduce any suspicion. To a woman the 4" coil is very 'jewelry' like. If it gets to be the size of drill then problems occur. It begins to look like machinery or weaponization. Old PC cases also become very good shields to testing and hide the devices. The common cry is 'What are you doing with all those PCs? They don't even work!'. Wuhahahaha!
Magluvin
Killer
Are you suggesting that if someone builds this, that THEY are out looking for and able to detect if someone is running such a device?
Mags
giantkiller
I have fried a cable box, tripped GFIs and scrambled routers in other parts of the house.
The signature is very damning and outside of the normal spectrum.
Have not the previous men stood up? I don't think so. Only brave clandestine attempts can be made to deliver.
Quote from: Magluvin on April 28, 2010, 12:32:43 PM
Killer
Mags
I have the second coil made to spec for testing.
The iron core in the right side coil is mobiously connected in a vortex configuration. The core loops in layer 1 then jumps up to layer 2 then jumps up to layer 3 then jumps back down to layer 1. It is configured like a permanent magnet holder.
e2matrix
Killer
Mags
Might be but I took it to be GK's wife saver routine.   ;D    If these are really doing damage around the house though it would sound like possibly scalar energy getting loose.  Hopefully not though as I think that's a bit hard to shield.
  GK,  in a recent post you said you were getting 125 volts out of a coil just sitting?  No pulse circuit hooked up?  While I saw SM's TPU stuff many years ago I just found a renewed interest here recently.  With all the big boxes of cable and wire I've got sitting around I think a TPU is a project waiting to happen here...
giantkiller
Yes. I was refering to wife. The 4" set of coils are working models of 18" diameter version. The 18" models were too visible as in big is bad. You get the picture?: Big coils, boxes crashing, wall outlets vibrating...
She saw the big coils and blamed them without knowing. I removed them. Now I know why mad scientists live alone. The political shuffling is killing me. Anyway...
And yes I only have 3 fet driver boards hooked up. Dead! I tell ya! No battery connections and no instrument connections or grounds. I have been disconnecting everything to find the source. Probably just a big antenna. I place my isolated VOM on the bridge output momentarily just to see the 125vdc. If I leave the meter on it settles to 33vdc. So: meter off circuit the coil pops LEDS / meter on circuit the LED momentarily flashes bright and the voltage drops, remove LED the voltage moves back to 33vdc. Put the LED back on the 'Meter on circuit' and the LED momentarily flashes bright and the voltage drops. Like an ambient Joule thief. It is a rats nest of jumper leads.
I will youtube it and show the mess but will clarify the 'no connections' visually. Bolt told me 2-1/2 years ago to get on batteries. I have been off the grid in my experiemtns ever since. I even bought an isolated OWON portable scope/vom.
Why me, Lord? I just want a TPU! It is just a small request but I have to go to both ends of the universe and learn everything in the middle? Agh!
This is not a trick or fanfare play. I don't have time for games. This is just a byproduct of something else I was pursuing. As Alexander Graham Bell exclaimed "x*-34fgr!" when he got burnt by acid as he was trying to invent the telephone. Go figure. When the LED popped I exclaimed 'Ah, damn!' Then I researched the problem out to find it was something needed all along. Guess I'll go down in the history books as a famous inventor too. ;D
Quote from: e2matrix on April 29, 2010, 05:22:36 PM
