Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
sparks
  Loner
     If you read Tesla's patents on the Magnifying transmitter you start to see why the Tower came tumbling down.  Say you have a watt second appearing as a wattnanosecond.  You would have a 1 billion watt transfer of energy from your system to wherever.  Heat anything with one billion watts and it goes away.  Nature appears to do this little trick when it creates a blackhole.  The blackhole creates an event horizon.  It creates an event horizon because it is storing the energy that creates time in modified space.  When and if it decides to return the energy that manifests time then you get stuff like big bangs going off.   Imagine being able to deconstruct the hoover dam in a nanosecond.  You do it so fast the water cant even move.  You would have a wall of water just standing there and then wham.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wings
Quote from: forest on August 16, 2010, 05:13:56 PM
is Earth rotating within magnetic field or both are rotating in the same manner ? I don't know.If somebody know ,he is very lucky.however in both cases any ripple on magnetic field will look strange compared to non rotating point of view
Tombe:
"I. The Earth’s magnetic field does rotate with the Earth. We can see this
clearly due to the fact that the Earth’s magnetic axis is not aligned exactly
with the Earth’s rotational axis. However, the Michelson-Gale experiment of
1925 indicates to us that the medium in which electromagnetic radiation is
embedded, may not be fully partaking in the Earth’s rotation, if at all."
http://www.wbabin.net/science/tombe17.pdf
Magregus
You can get power from a magnet you just need to know how.  Try thinking outside the box.
http://yfrog.com/9ftpubj
sigma16
Quote from: Loner on August 16, 2010, 11:20:00 PM
For the first time, I am truly questioning the safety of such a thing, as once fully "Charged", and especially if large "rotational" forces are built up, then collapse of the bias field would be a NO-NO.  I would figure the response time of the energy output as "Too Fast to Compensate for".
Alternative energy and space propulsion research is not for the "timid" or "weak of heart".
sparks
     Tesla use to build tanks that had millions of horsepower in them.  If you tip a tank over that has millions of horses running back and forth in it and they all run in the same direction this is called a stampede.  You dont want to get in the way of a million horse stampede.  You dont need to mutate mass or rapidly oxidize a fuel as long as you can turn highfrequency events of miniscule individual power into low frequency events of high power.   That is basically what a plant does.  It inputs ultraviolet and stores the energy in chemical bonds.   You will notice that a plant like an animal is a low power machine that takes up a shitload of room is inefficent and exists in a very limited temperature realm.  Water is another thing.  It absorbs infrared the most common form of electromagnetic radiation on Earth and just gets hot.  As it is heated the thermal photons it admits change frequency.  Warm water emits far infrared frequencys.  If we can tune into some xray galaxy a billion trillion miles away we should be able to tune into some warm water a couple of feet away.  The antennae has to be so tiny weeny to grab the near infrared frequencies that it is being promoted because the nanotechnology industry can hook up with the fire burners and convert thermal photons of near infrared into dc.  Meanwhile we have a superabundant scource of radiation of thermal photons at far infrared frequencys that are being totally ignored.  Why would the power and communications industries ignore the most prevalent electromagnetic radiaition bandwith on in and around the face of the Earth.  Because it doesnt burn you and light up or go bang bang.  It is all over the fucking planet in the water under the water into the Earth.  No gotta drill down and get that real hot geothermal.  Because it is hot.  Cold stuff longer wavelength.  Hot stuff shorter wavelength.  Hot stuff not so much around sporatic transmission varying bandwidth no good when it rains snows or you dont have acres of land to put down acres of melted sand.  Warm or cold air.  Lots of it around.  Longer wavelength.  Available night day and weekends.   Requires no land.
Think Legacy
Spread the Love
