Magnetic Experiment Confirmed!
Started by PaulLowrance, October 24, 2009, 01:49:14 PM
PaulLowrance
Just now the two nuts separated by dry paper was less than 1mV.  And the two Ferrite magnets separated by dry paper is now up to 80mV.
What I'm doing is letting the parts sit undisturbed without the clip leads. So it's not connected to anything. And then every so often I'll connect the electrometer clip leads to take a quick measurement. As comparison, most diodes are so sensitive that if I took more than 1 measurement every two days that it will begin to slowly become disturbed. Piezos on the other hand seem far more powerful in that they can take a lot more abuse; i.e., measurements. We'll have to see how the magnets hold up. So far they seem more sensitive than the piezo, but better than the diodes.
Paul
PaulLowrance
Just thinking out load here, maybe one aspect that produces the DC voltage is caused by the magnetic field flowing through a *change* in material from conductor to insulator. IOW, various esoteric sources claim that substance that we are unaware of flow through the magnetic line, and perhaps the sudden change from flowing from the metal to the insulator causes a slight interaction with matter.
Paul
powercat
I have now done my Cap Test the way you suggested Paul, before I connected the 400v 1uF cap  I checked the voltage coming from the magnet 148mV [With leaf]
I waited for about 15 minutes then quickly disconnected the cap and got 3.5mV,
and yes I did remember to check it was empty before starting.
AboveTopSecret forum
there was talk about using wax paper or polyethylene  as I have no wax paper I used some
polyethylene, I tested with four different types though none of them would produce more than about 7mV.
a member on the forum was claiming there is a thread over here  ::) I can't find it
Quote from AboveTopSecret forum
If you go to overunity.com, you will see that they have already started running LED's off of my Magnet Battery for FREE.
Yes there IS such thing as free energy.
You see... ALL ENERGY IS FREE. You just need to know how to trap it, and circulate it. When you do that, you have electricity. The Magnet Battery never runs out, because not matter how many electrons you pull from it, the "protons" automaticaly gain the electrons from the Earth and the atmosphere!
on 31-5-2008 @ 12:21 AM by ALLis0NE
cat
powercat
@all
can anyone get this download to work ?
http://www.free-energy.tk/magnet-array-in-series-overunity-com.html
if you scroll down a bit you will see this.
magnet array in series. overunity.com
testing
the theory of using wet paper between the magnet and the keeper induces a charge. seeing if we can measure current.
Read the whole article here.
click on where it says  here , my download seemed to get stuck on the last bit
cat
Edit
if you click on News or links or about us at the top of page you will be back at this forum
Mk1
@all
I few things to keep in mind first the magnet keeper , it cancels the magnetic current around the magnet and concentrate it in the keeper .
Test should show current providing that some insulation between the magnet and keeper is installed . I could not find the link where i the test was conducted, sorry .
But it used a iron magnet with the paint scratched off at the top of the U(to connect the meter) shape , insulating paper between the magnet and keeper (the second meter probe is connected to the keeper).
Since the the magnetic current around the U shaped magnet is canceled and concentrated in the keeper is it still considered stationary ?
You can test the magnet and magnet with keeper on old monitor of tv screen , to see the dramatic change.
Second of all .
This is really not unlike Roy J Meyers absorber , he used zinc and air insulation , he did not have neo's north and south orientation may be less relevant but he dose look like a dual system , both of them working in opposite direction .
http://www.rexresearch.com/meyers/meyers.htm
