Has anybody found Ou?
Started by onthecuttingedge2005, October 25, 2009, 09:49:35 PM
Comassion
I also wouldn't want radioactive material spilled on me in the event of an accident.
I'm curious though - why do you see nuclear fission as a form of OU?  The way I see OU is that it is some device that produces more energy than it requires to function - and when you use a form of fuel, you're putting a whole lot of energy into the device.
Kinetic energy without the need of gravity can actually be CREATED out of nothing, yes you heard me right, easily. Look at pequaide's work and this channel:
http://www.youtube.com/user/broli123#p/u
This simple device allows you to create many kilo joules of energy in a fraction of a second time. It's all based on the simple principle of conservation of linear momentum over energy. The COP of the device can be adjusted to any level if the speed and size are feasible. But COP of 10 would be possible by anyone who's not busy procrastinating.
dankie
No it wouldnt work , I will  procrastinate an say it cant run any load , it has no  power and it wouldnt be easy ,  it would be  impossible .
@ best it can run forever if there is 0 friction or load .
Comassion
Are you referring to the CG device in the last video on the channel?  If so, I don't see how it is creating energy.
Quote from: dankie on November 04, 2009, 11:26:56 AM
Thanks for your armchair opinion. I guess the energy Pequaide and I'm creating with these setups is imaginary too. Spend some more time than the 5 min of research you just did and educate yourself.
