0 Members and 65 Guests are viewing this topic.
Bruce_TPU
Quote from: lumen on January 16, 2010, 01:39:33 AM
Is there a neutral line between opposite polarities or is it only same polarities?
Wouldn't the neutral point only exist with a single rotor magnet or two magnets of the same polarities like the JLN test?
Hi Lumen,
The two magnets are NOT of the same polarity in the JLN test.  Please see picture below.  I have circled it in yellow...  ;)
Cheers,
Bruce
k4zep
Quote from: PaulLowrance on January 16, 2010, 09:37:39 AM
Either with ultra high permeability material or ~ a 1000 turns with common material. The way only it could be 1000 turns is if there are hidden layers that use microscopic wire.
I've concluded that Steorn must at least have a square loop core in order to get the scope shots they're showing.  :)
Slowly but surely we're figuring it out.
I agree.  Well I have a pile of normal cores and a few Metglass cores to be here in 3.4 days.  I can easily get more than 1 H with 4-500 turns and appears with a RL network (see JLN's newest video) at a particular voltage you can get that square wave....As you say, it slowly becoming clearer.  I suspect many ways to skin this cat!
Ben
PaulLowrance
Could you people help me out here? *Please* go to -->
http://network-tools.com/
then click on radial button next to "HTTP Headers" and then paste one of the following web address into the field next to the "GO!" button? Do not type "http://", otherwise it chokes. -->
ambientfreeenergy.googlepages.com/freeenergydesign3-designc-proof.fem
ambientfreeenergy.googlepages.com/freeenergydesign3-designc2-proof.fem
ambientfreeenergy.googlepages.com/freeenergydesign3-designc3-proof.fem
ambientfreeenergy.googlepages.com/freeenergydesign3-designc4-proof.fem
ambientfreeenergy.googlepages.com/freeenergydesign3-designc5-proof.fem
ambientfreeenergy.googlepages.com/freeenergydesign3-designc5b-proof.fem
You will see a header like this -->
Header are:
HTTP/1.0 200 OK
Last-Modified: Tue, 24 Feb 2009 18:25:37 GMT
Cache-control: public
Expires: Sat, 16 Jan 2010 14:52:35 GMT
Content-Length: 10819
Content-Type: application/octet-stream
Date: Sat, 16 Jan 2010 14:52:35 GMT
X-Content-Type-Options: nosniff
Server: GFE/2.0
X-XSS-Protection: 0
Notice the "Last-Modified" date. This one was 2009, Feb 24th.
The more of the files you verify were last modified in early (February) 2009 the better.  :) You have no idea how much I appreciate it!
Thanks so much!!!! It would mean the world to me, as this is at least some evidence that in February 2009 I uploaded my designs based on a technique of using a toroid as a magnetic switch. I have always planned on making my designs open-source, but always planned on starting a business manufacturing & selling excess energy devices to people who don't want to build their own, that is *after* such technology is proven.
Also, IMO I'm not the 1st to re-invent this technique, but I would like as much evidence as possible in case Steorn ever decides to sue me. btw, I would never in a million years sue Steorn! Nor would I have grounds to sue them.
Also feel free to download and view the files -->
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc-proof.fem
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc2-proof.fem
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc3-proof.fem
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc4-proof.fem
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc5-proof.fem
http://ambientfreeenergy.googlepages.com/freeenergydesign3-designc5b-proof.fem
gravityblock
It's not really hard to get almost 1 henry with 37 turns with high permeability.  What he meant by a soft magnetic material is the domains turn easily.  Microscopic wire isn't going to handle 10 amps, you can rule that out.
Below is a calculator that will help you to figure this out.  Start with 37 turns.  Then play around with the relative permeability along with the core and coil radius until you have almost 1 henry.  Once you find the right combination, then you will have the core dimensions and will know what the core material is.  I'm just trying to help.  Maybe you already tried this.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indtor.html#c1
Did you know that Metglas trade secrets have been stolen.  A man was arrested on Dec. 23, 2009.  Sounds like somebody knows of the future potential in the explosive market regarding the Metglas material and wanted to capitalize on it.
GB
PaulLowrance
Quote from: gravityblock on January 16, 2010, 10:04:38 AM
GB
Can you show the example while using realistic values for the Steorn toroid because I'm getting 1mH for -->
Toroid radius = 2.3cm
Turns = 37
Coil radius = 0.38
Permeability = 2000
Inductance = 1.08 mH
You would need a permeability over a million to get close to 0.98 henries. Guys, I have an Amadon book that shows the inductance of normal cores, and cores with permeability of 2000 the size of Steorn's requires ~ 1000 turns to get 1H.
