Solid State Orbo System
Bruce_TPU
Hello ALL,
JLN Labs has posted a lot more information and advise about his SSGen experiments, as well as another video.  It is at the bottom of the page, here:
http://jnaudin.free.fr/2SGen/indexen.htm
Cheers,
Bruce
http://energyfreedomreport.com
mscoffman
Quote from: Bruce_TPU on February 16, 2010, 08:40:19 AM
Hello ALL,
Cheers,
Bruce
Thanks Bruce...Amazing! Someone should perform the above
experiment inside a largish iron or ferrite cavity. Maybe
formed out of 8" piping hardware or something similar. Also
with a hefty L + C lowpass filter spliced into the DC supply
lines.
:S:MarkSCoffman
JamesBe1
Hi folks.  This is my first post after lurking around here for the past couple of years.  I must say that am really impressed by the quality and intellect of the people here.  This thread has really caught my attention.  I’d like to say â€" Nice Work Groundloop for kicking this thread off!
Earlier in this thread I read several posts regarding finding the correct resonant frequency for the input.  With that in mind, I wonder if it might be possible to take the ac from the output and use it to pulse the input torroids.  Assuming of course that we could get the frequency correct.  It would in effect create a self running generator (which is what we are all chasing after).
I can’t help but notice the similarity between what that would look like and one of Steven Marks TPU’s.  I can’t find a great picture of it on the net, but I attached what I could find.  Every time I see this video I am struck by what appear to be probably four magnets placed about the circumference of the device.  After watching the video again, I now notice the heavy copper wire which is probably the pickup coil.  Could it be that what Steve Marks made is very similar to what is developing here?  I have no doubt whatsoever that Steve Marks covered up components and added extra useless components to throw people off the track.  Also I have no doubt that Steve Marks disinformed and misinformed people about the fundemental workings of his tpu’s.  I may be totally wrong, but I think that the tpu in the attachment might be a meg with the output coils pulsing the input coils as mentioned above.  It’s possible that what is discovered here might be the key to the tpu secret.
I just thought I would throw this out to the group as nobody has said anything.  I see an obvious parallel to at least on of the tpu’s.  Thanx for reading.
James
Groundloop
James,
Welcome to the forum. I actually agree with you, there are many people
that is doing great research right now. And I'm sure that some day we
will break the free energy barrier. The fact that a little toroid can shield
a magnetic field was a great eye opener for me personally.
Groundloop.
JamesBe1
Thanx Groundloop.  This thread has inspired me to get off of my backside and start winding.  I have a great deal of experience with test equipment.  As soon as I fix my pulse generator I'll be able to start testing and sharing my results.
Quote from: Groundloop on February 16, 2010, 04:43:01 PM
James,
will break the free A barrier. The fact that a little toroid can shield
Groundloop.
