Solid State Orbo System
ramset
Omega O
quote:
Clearly, most people don't know what COP is. It must be restricted to heat and heat only, nothing else.
Quite true ,however to state the profoundly obvious.
You could go "loopty luuu..........[hopefully where this is heading]
Just so everybody is happy! =:]
Chet
Thanks Grandma
Bruce_TPU
Pleasant Evening ALL,
Well, I have added my 5th Brooks output coil, located at the very bottom of the bottom toroid, in parallel with the other four....
First I tested it alone at:
1.045      V
70.3        R
0.01486   I
0.01552   P
Next I wired it in parallel, (you must test the leads, because if I put the leads on the wrong side and it cuts your power in half!) And the following is what happened:
3.15        V
33.1        R
0.09517   I
0.2998     P
This one coil BOOSTED TOTAL POWER (wattage) output by 61%
One more Mr. Brooks to wire up and then time to really have some fun!
Cheers,
Bruce
http://www.energyfreedomreport.com
Bruce_TPU
Hello ALL,
6th Brooks coil is now in place, and below are the stats!
Top and final Brooks coil by itself:
.719       V
71.3       R
0.01008  I
0.00724  P
Now, what happens when we connect this WEAK coil in parallel with the rest?  Hmm...
3.25         V
29.5         R
0.11017    I
0.35805    P
20% OVERALL INCREASE IN POWER!  Very Cool!
wings
Quote from: teslaalset on March 02, 2010, 03:36:49 PM
Naudin has withdrawn his part 7 on COP of 8.1
news:
http://jnaudin.free.fr/2SGen/indexen.htm#ratio
l  = ((Vdem^2)*10000) / ((Vmag^2)*10000) = 13.8?
gravityblock
Quote from: wings on March 03, 2010, 04:28:37 AM
news:
If you round it up, then it is 13.8.  After reading the reference materials provided by Naudin on the magnetization-demagnetization of the core and the way this experiment is performed, I will have to agree the 13.8 is a good indicator of COP.  Next step is to close the loop.  ;D
GB
