Magnetic amplification and neutralization motor by Art Porter
Started by LarryC, February 20, 2010, 05:07:38 PM
alextecmen
This is the way of working of the activation of the relays.
Cycle Description:
Step 1. Relay 1 is energized for 30 milliseconds.
Step 2. Relay 1 is de-energized for 10 milliseconds.
Step 3. Relay 2 is energized for 30 milliseconds.
Step 4. Relay 2 is de-energized for 10 milliseconds.
Returns to Step one and repeats as required.
24 VDC relay   Dayton   5YP80
alextecmen
greetings to all
Continuing with this project and experimenting
I have 2 "x 0.7" magnets to test
I am going to carry out the project of the coil without movement, without moving parts, initially I am going to test with a coil that I have from a Bedini motor
So I will try different coils, any suggestions or comments welcome
alextecmen
Well I used the two opposite magnets in polarity with the coil, I fastened it with tape, or I was surprised to give it 24 v voltage, the top magnet shot out, with the luck that it did not hurt me and it was attached to a metal plate, I trust it is so strong momentum.
The coil applying the 24 volts consumes 3 amps, I am going to hold the magnets well to prevent it from flying off, I want to see how much energy I can have from the recoil of the cut of the emf.
I wanted to show you images but the page does not let me upload them, how much can I show them
alextecmen
I already tested the coil with opposing magnets, that is to say in the between the coil with equal polarity, the coil the core I have is a welding rod, when I put the magnets opposite to the coil core, the two were slightly attracted by core, I don't have the core that Mr Porter uses.
I held the magnets well to the coil so that they did not fly away, I applied 24 volts to it, manually, that is, I connect and disconnect the cable freely.
I put a car bulb, 1.5 amperes in series with a rectifier to use the recoil of the emf, but it did not turn on the bulb, then I put a 12 volt led bulb, and it turned on very bright when I cut the power, there it was back fem was present.
I'm going to have to get the nucleus that Art Porter proposes.
What if the great repulsion and force of the rejection of the magnets is present.
I was left with the desire to obtain energy and to turn on the car bulb, and it did not turn it on, only the 12 volt led
De que material propone Art Porter para el nucleo de la bobina?
synchro1
@alextecman;
Quote from you:
"I wanted to show you images but the page does not let me upload them, how much can I show them".
Do you know the procedure to capture a screen shot? What kind of operating system are you using Mac or Windows.
