Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 194 Guests are viewing this topic.
The Observer
Tseung,
     It has been my experience that perfect resonance results in a sine wave even if there is a DC pulse input.
     See Image below.
Xs,
        Keep in mind that Stefan put this thread in the OU prize Area.
        Tseung has never officially applied for any OU device.
     Anywho...
     It really doesn't matter if Tsueng is doing a viable project or not... you are not speaking for the forum
                                                         if you are asking the man
        to stop experimenting and sharing his results.
         If you think that Resonating Ferro Magnetic Transformers aren't interesting... then start a thread on it... and post often.
        Do you realize that a piece of iron Magnifies the Magnetic Field of a Coil by 5,.000 times without any extra current needed???
        Have you ever considered that an Acoustic Guitar is 1000 times louder than an Electric Guitar (Same String ... Same Strum)
Best Regards,
                         The Observer
ltseung888
Quote from: The Observer on September 05, 2010, 12:56:00 AM
Tseung,
     See Image below.
Xs,
     Anywho...
Best Regards,
                         The Observer
Dear Observer,
Can you explain how you achieved resonance in your series of diagrams?  Did you use signal generator to change the frequency or did you try LCR resonance tuning?
In your result, the resonance Vpp is about 15V.  The number of turns of secondary to primary was 200/15.  That was close to 15 times.  Thus your system followed the classic transformer rules.  In our Joule Thief/transformer circuit, the windings can be 1:1 but the Output Voltage can be > 10 Input Voltage.
An explanation of your result will be helpful.
XS-NRG
Lawrence Tseung Does Not Even KNOW What RESONANCE IS!!!
It is obvious that he is unable to read scopeshots or have any clue what they mean or what to look for.
rave154
lolololol @ "Lawrence Thief with embedded scam"
i wonder how long it will be before tseung gets out the fishing line and small dc motor hidden under the couch cushion?
chrisC
Quote from: rave154 on September 05, 2010, 03:18:39 AM
I don't think Tseung is a thief as such but a sadly deluded fellow whose understanding of electronics is limited but tries so hard to grab onto bits and pieces from other forum threads in order to try build some sort of 'believable' O.U story. Unfortunately there aren't too many folks buying the story line.
cheers
chrisC
