Gulf Oil Spill - new record
Started by 4Tesla, May 01, 2010, 08:49:16 PM
giantkiller
sparks
     The gas is a huge problem.  As it float up it expands and would tend to rupture any pipes attached to a well head manifold so the manifold would have to seperate the gas from the oil.  I have this feeling that the gas has ruptured the well in the upper sections and is going somewhere else.  I just dont see enough bubbles in BPS video feed.  BP have a handle on how many cu miles of natural gas is hitting the atmosphere yet.  Talk about a warm breeze off the Gulf.  How bout one that explodes.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
The gases and heavy metals are what Lindsey Williams and  Alex Jones are talking about. The pressure caused sepage perpendicular to the well underground. This horizontal push is entering between the stratus  at different levels and causing calderas and fissures 20 miles away. The air is already filled with benzene flowing over Tampa / St.Pete. We should start to see respiratory failures in the elderly community.
Again: http://www.youtube.com/watch?v=SYhugmaAL3A
The Jihad has started.
wattsup
Quote from: sparks on June 17, 2010, 06:01:17 AM
     The gas is a huge problem.  As it float up it expands and would tend to rupture any pipes attached to a well head manifold so the manifold would have to seperate the gas from the oil.  I have this feeling that the gas has ruptured the well in the upper sections and is going somewhere else.  I just don't see enough bubbles in BPS video feed.  BP have a handle on how many cu miles of natural gas is hitting the atmosphere yet.  Talk about a warm breeze off the Gulf.  How bout one that explodes.
Yes you are very right about the gases but that is not a problem. I have made a new diagram to show what is required to stop that leak.
Basically, to separate a good percentage of the gases from the oil, each manifold enters the sidewall and the riser part has a gas deflection cone so gas does not get entrained into the pump suction. So 14 of these placed around the tank and a center off gas opening to let the gases rise. Even if they expand as they rise, there is no holding it back.
Regardless if this tank is in 100 feet, 1000 feet or 5000 feet, it does not matter. The tank will have the same pressure outside as inside so all that is required is a few pressure sensors and variable drive pumps to keep emptying the oil as it fills the tank.
There is no other way.
If I was the President, I would have all the major oil companies that are doing deep sea drilling to pay along with BP the fines because none of them have any better advanced plans to stop a leak hence any one of them could have had the same problem leak. They are all a bunch of pea brained bastards. They drill into our collective 3rd rock without giving a shit of the consequences.
CompuTutor
