aluminum can and copper wire batterys
Started by old man, June 24, 2010, 04:33:10 PM
the_big_m_in_ok
Quote from: old man on June 26, 2010, 11:27:14 AM
all
started new test with two cans
white vinegar and water
vdc       ma
.635      .269
bleach water
1.027      .273
lemon juice water
1.116    .141
The Observer
could you let use no what your getting with your setup if you could ples thank you
The Observer is correct in saying the final voltage of a steel/copper water battery is about .6-.7 VDC.
It takes a couple of days for the cell to actual get to that voltage in an open circuit.  The only cost to me is the wire.
Do your vinegar/bleach/lemon-juice batteries give more voltage over time like the steel/copper ones?
What ohmic value of resistor were you using?
Research questions for future study:
Can these batteries be made to act like a backup UPS with a trickle charge applied to them over time?
How long will one hold a charge if it sits on a shelf unused for awhile?  Will the charge decline over a lengthy time period?
--Lee
infringer
ROCHELLE SALT try this stuff out it is used to make piezoelectric crystals which generate electricity ...
Maybe you'll have something then worth a shot...
Maybe try the bargin bottle with 1031% more from walgreens of aloe vera with some rochell salt...
Aloe Vera has an acidic pH which helps to encourage the body to secrete proper amounts of hydrochloric acid to improve digestion and absorption.
Being that it is gel it may last longer IDK worth a shot though!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
the_big_m_in_ok
Quote from: infringer on June 26, 2010, 05:57:20 PM
Maybe try the bargin bottle with 1031% more from walgreens of  with some rochell salt...
http://www.reference.com/browse/rochelle+salt
Well, maybe?  This is potassium sodium tartrate.  Dissolved in water, it might act like a salt, since it actually is a salt, but money spent on the stuff and research into voltage generation would be necessary, yes?  Electrically, unless there's an unknown factor somewhere, it's just a chemical salt.  I could check out the price at Walgreen's, if they sell it.
LATER REEDIT:
I checked at Walgreen's:  No Rochelle salt for the same use as Epsom salts to soak in water for sore feet.  However, they did sell an electrolyte for babies who suffer from diarrhea or vomiting to replace natural electrolytes, but it goes for US $6.00/qt (or liter equivalent).  It had salt and other things in it.
It occurs to me that diluted soda is also acidic and inexpensively available everywhere.  Not mush should be needed in tap water.
--Lee
old man
lee
i hate to be dumn but what does What ohmic value of resistor  mine i dont no
will see how long they will hole a charge these can with vinegar/bleach/lemon-juice are going to be my controll i not going to add anything to them and aee how long they will list till the reading are 0 or no water in them my first test is for 5 days and then i and going to see how long i can keep a led on and so no till i have 12v all the time and that even with a load on it and even if it says at 12 v for a week or month it wood be good
infringer
where can you get
ROCHELLE SALT  at ill give a shot and see what happens
thanks for all of the help you guys
tom
infringer
I actually have a big tub of it but usually your local supermarket...
I am just shooting in the dark here no sound principals at all to tell the truth!
I will tell you what maybe I will preform the expirament myself here and save you the hassle !
Hell they sell it on ebay as well I think...
-infringer-
-infringer-
