Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
7redorbs
Here are some pictures of my experiments with a Wooden block and a steel conduit in a PMH circuit. It reveals what I named possibly correctly as the Blue LMD Vertical Wave Emission, which may be being misrepresented fully by the Camera. It appears with the wooden block I have caused the LMD vertical to bend into vortex and pyramid shapes.
Because of the complexity and strangeness of these observations I am attaching the picture for the reader to decide and experiment for his or herself.
Best,
A
scotty1
@ Derek, the reason Ed talks about facing East is because that is how you are positioned while doing all his experiments.
EG: the copper wire is positioned E/W....the battery is South of the copper wire, pos terminal East, neg terminal West.
The experimentor is standing South of the copper wire on the West side of the battery.....which means you are standing in the S/W....facing East as you tap the neg terminal.
In the experiments with the PMH the experimentor pushes the 3" coil from West to East through the PMH prongs...the North pole prong being on the North side and the South pole prong on the South side.....so again you are standing in the S/W, facing East.  ;)
Scotty.
scotty1
@ Redorbs, could you post a drawing of your setup and the connections to the battery ect?
It's a little hard to know exactly what you are showing.
sparks
  We need not throw out all quantom physics in explaining Leedskalin's PMH.  A low energy electron in a 1 or 2 s orbital packs the punch of 1 milliampere.  In a mole of atoms 6times 10 to the 23rd power.  Take out 3 powers.  10 to the 20th amperes in one mole of atoms.  The initial current supplied to the pmh acts to align molecules of iron so that the resulting currents about the atoms assemble in some sort of order as opposed to the disarray produced by atomic and molecular heating effects. You take Leedskalins or any permanent magnet and heat it or smack it and away goes your order returning to chaos.  You slide the keeper aside and the currents once ordered disintegrate and the prime and most important rule in electromagnetism bubbles up.  Change the magnetic field about a free charged particle and the motion of the particle will be altered. Tesla invented the ignition coil which exploits this rule to produce high voltage.  The forward current "magnetises" the core while the points dwell. This is often accomplished through a ballast load.  Then the current is abruptly halted.  The energy stored in the magnetic density of the core material over say 500 milliseconds is released in 1 millisecond. pop goes the fossil fuels.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
derekwillstar
Quote from: scotty1 on May 04, 2012, 11:27:26 PM
Scotty.
@Scotty , I think the reason is another, Leedskalnin invites us to look to the east because of the deception we suffer!
He writes that he was lucky to build a telescope coral castle and invites astronomers to take a look ...
I mean even if you take me for a madman:
;D
According to the theory of "law of rhythm" by Pier Luigi Ighina, everything is still in the solar system, planets and moons property. (pace Galileo Galilei)
http://www.fortunadrago.it/?page_id=279&gtlang=en (take al look)  :o
The sun with its rotation emits pure positive magnetic energy that behaves like a "glue Universal Magnetic" which it sticks around: light, heat, radiation.
http://www.youtube.com/watch?v=oH7yuBFQAAA (take a look)  8)
In its progress in space, energy makes a spiral movement (there is no "straight road" between sun and earth) , but the movement of magnetic energy, coupled with the rotation to result in the final rotation and orbit any celestial body in the solar system (including Earth), because matter is an obstacle to the movement of energy that ends up joining the first and then reverse.
In the end we see the sun rise and set, we actually see the movement of the "universal magnetic glue" that in carrying with it the light.
a movement of the strobe light to which all are deceived!
:P
