Thanks to ALL for your help!!
this will get rid of arthritis.
Started by 11:11, July 29, 2010, 08:57:46 PM
11:11
Quote from: the_big_m_in_ok on August 04, 2010, 08:27:18 PM
Well, okay.  I'll have to take your word for it.  No permanent damage to the body?  Things like a 1,000,000 Volt Tesla arc lightning bolt while you're fully grounded to earth?A Cherokee shaman told me that's why shamans live on hilltops.  The energy is so positive.  Because I'm Native American myself, I can appreciate this point of view.
--Lee
things like living the worst horror movie,
that you ever watched.
only far more scary,
than any existing horror movie.
i don't know if it was possible for them to kill me,
but they certainly wanted to.
and i get the impression that my astral body,
has been extensively lacerated,
by cuts.
electricity is moving electrons,
and positive ionization is more or less empty of free'd,
movable electrons.
so electric arcs could violently move "towards" positive ionization,
but are much less possible "inside" positive ioniaztion.
the lightning balls that they sell at spencers,
are full of negatively ionized gas.
so arcs of plasma-light,
are much more possible,
inside negative ionization.
crowclaw
Many years ago we use to sell Ioniser's " Mountain Breeze" was  the marketing name. These could be purchased in various sizes, but they were a 'hard sell' product... trying to put over their health benefits was not easy, and not cheap. Over a short time they lost popularity and we stopped selling them. However on occasions I used one myself and  felt quite refreshed but fell out of the habit and forgot about it. I don't know what happened to it! I'll re visit this concept and put it on my list of pending projects, it's easy enough to replicate. Does the frequency make any difference and should it be pulsed does anyone know?
11:11
i got the impression that store purchased ionizers,
created the positive and negative ionization,
close to each other.
to the effect,
of the positive and negative ions,
quickly re-combining,
into neutral ionization.
to have the negative ionization build up inside a room,
you have to ground the negative terminal,
to the dirt outside.
so that the negative charge,
which attracts the positive ions,
is distributed through out the entire earth.
leaving only the negative ions,
building up like mad,
on the positively charged terminal,
which is sitting inside your house.
the frequency DEFINITELY makes a difference.
the higher the frequency of the electricity,
the more the electricity IGNORES the electrical resistance,
of the physical objects around it.
10 watts,
at 60 hertz,
will not go through the insulation,
on 14 gauge copper wire.
but 10 watts,
at 6,000,000,000 hertz,
will go right through the insulation,
as if there was no insulation on the wire !
like a jedi light saber,
cutting a storm trooper in half.
the reason why they cannot milk amperage,
from a wimhurst machine,
is because the wimhurst machines electrical output,
is so high in frequency,
that the electrical output IGNORES the resistance,
that allows a diode to work.
even a high-rectification microwave diode,
cannot even begin,
to turn the high frequency wattage,
into DC wattage.
11:11
i remembered an experiement,
that an ex-friend of mine talked about.
there were 2 separate cages.
each cage had a family of rats living in it.
one cage had the positive end of a strong magnet facing it.
the other cage had the negative end of a strong magnet facing it.
over time,
the positive pole rats,
were less intelligent,
were more aggressive,
reproduced more pinkies,
ate more food,
and were physically bigger.
and the negative pole rats,
were more intelligent,
were less aggressive,
reproduced less pinkies,
ate less food,
and were physically smaller.
in both cases,
they were still dirty damned rats.
i suspect that the positive poles magnetism,
had the effect of positive ions.
and the negative poles magnetism,
had the effect of negative ions.
which means that positive and negative ionization,
definitely effect you.
and you obviously want the negative ions to effect you.
there is a large amount of positive ionization,
in large noisy cities,
due to all the negative
cement,
steel,
and electronics.
which seems to be part of why trouble makers are found in large cities,
and peaceful/quite people,
are found in the countryside.
i'm sensitive to ionization.
large cities feel like the kiss of death.
where a river flowing through a forest,
feels like the breath of life.
fritznien
magnets are north and south poles not negative and positive. they are not the same at all.
which end of the earth is the smart end?
