The Peace Maker
Started by Quantum_Doogy, August 12, 2010, 08:04:00 AM
Do you think this would work?
No
1 (33.3%)
Have no idea
0 (0%)
Maybe
2 (66.7%)
Yes
0 (0%)
Total Members Voted: 3
Thaelin
   You should never allow your self to be told something will
never work by EE's. Not saying they are wrong, but they are
taught from a set of books that taught their teachers and
their teachers and their... well you see what I mean. We fly
because they refused to believe what was said and did it anyhow.
thay
Magluvin
Quote from: Quantum_Doogy on March 24, 2011, 06:03:59 PM
Update:
A very sharp engineer that I highly respect had taken a look at this and he told me it will not work. I still am not sure where I made a mistake on it but I am certainly taking his word about that.
Like Thay said, you wont get good advice from an EE.
As above, you said you didnt know where you went wrong. If the EE knew, he would have told you.  But he doesnt, or you would know from him what the problem is.  ;)
mags
wattsup
You might want to look at Thane Heins.
wattsup
Quantum_Doogy
Update2:
A while back I posted "A very sharp engineer that I highly respect had taken a look at this and he told me it will not work. I still am not sure where I made a mistake on it but I am certainly taking his word about that. " Later I found out he did not even bother to give a try to look this device over just because it was connected to OU he automatically did not even consider it and just said it would not work because there is no such thing as OU. I personally agree for the most part there is no such thing as OU as in no external energy source goes, but if there is a fuel/energy source such as pulling energy from another dimension such as ITM (zero point), or have certain materials configured in such a way to allow for lower input energy to produce higher output energy that require a fuel source such as the sun or some noble gas fusion process, or some certain arrangement of magnetic monopoles but magnetic monopoles are not easy to make yet, or Tesla coil tapping energy out of the atmosphere pulling a part of the natural charge difference between the earth and the air, or by recycling energy such as capacitor bank open circuit system combined with a certain chemical process ;-) Yet then such things are not really OU, but just use of a fuel/energy source from elsewhere. So then it comes down to whether OU is about breaking the laws of nature (not possible), or OU is just using less energy to make more energy from another fuel/energy source (possible) in like a waste site making methane could be considered. So what does OU really mean, to some it is breaking laws of nature, to others is it a way to use less energy to trigger a process to make more energy which applies to many known things, however it is not OU as many perceive but a way to use some external source of energy from a limited or unlimited supply, maybe just because of a relative syntax of OU leads to many to not even look, so maybe a word we should be using here is alternative energy source (AES), which reminds me of something a great scientist said that I hear mis-stated a lot that is nothing can travel faster then light, but that was not what was said, what was said was basically nothing with mass can travel faster then light within this space. One comment leads to not even considering such a possibility, the other comment leads to potential consideration of such a possibility.
With this device if it works, I still do not know for sure, but the concept of where the extra energy comes from is that it recycles the input energy when have input pulse on, the unique configuration of the coil plus magnet appear to allow for recycling the input energy on a set of output coils, and when the input energy is off the change in the magnetic field induces energy in another set of output coils.
Any 2nd opinion is welcome pro or con.
Still not one other person I know of took a real look in to seeing if there is something here or not...Anyone interested in at least calculating or simulating it to see if it would work or not?
Tcanuth
I shall call it the flux capacitor....
sorry had to make the reference as the design reminds me of it alot
