a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
i noticed that when i was triangulating it,
its not drawn with enough precision.
its "off" a bit..
what i noticed is... their phase
they are 180-degrees apart.
meaning when one fluxuates "north", the one on either side adjacent to it is fluxing "south".
This sheds a lot of insight on a point someone made earlier, as "what happens when they're odd numbers"
(sparks? maybe?)
we would have to deduce this to prime-odd numbers, each non-prime odd number would have the same frequency response.
2/3 , 2/5, 2/7, 2/11 ect. and you will see the phase differentials between the tubes.
david lambright
hi twinbeard...thanks for posting!...you are familiar with Mandelbrot i understand....his sets are a description of a flat plane vortex? ...Fibonacci's spiral and the Mandelbrot sets should go together...i believe that the way that all plants grow follows a magnetic pattern...the same pattern like you talked about...the helix...when this radiation is made to vortex it gets very strong....can you tell me more of Mandelbrot and Julia?...thanks....david
cletushowell
Dam spark i thought this was going be top secrete i guess
it not no more you just hit the string too
move your two dots to the middle black and white
now you have your
++++ triangles
the twelve triangles of 12,000
just cross your dots with a x three of them
so much for science its busted
sm0ky2
Now,.  as we discussed earlier,
the induction originates at the point where the tubes meet.
This means that BOTH sides of the tube, are pulsing north AND south, simultaneously.
one from itself, and one from the tube next to it.
i dont know how to explain that so it makes sense...
its like a "DC" magnetic pulse current at ~ 281 Ghz
if you want to know the polarity theres a point between the "gap"
just on the inside of the metal
you can suspend a magnetized piece of needle on a string and it will act as a compass.
cletushowell
You get exact cuts of the pipes when you line the third ring up with the second you see they are not ezactly equal but are
they alternate ill be in court dealing with my stuoid earth
battery arrest tomaroe then ill post the correct key
you have it already but you need to line the rings up
smoky but you have string theory now
well the points ill fill you in on the lines
tomaroe send me your email
so i can fill you in
