a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
coming up on 50,000 views of this thread!
Hope
Did you get my concepts docs    wanted to share it with you and all   it is the key to understanding how to tap the sea of energy we are afloat in   your device creates a collection of zero points   what you see is energy leaving time and space to be reborn.  Ed Leedskalin device did the same thing   notice all the null points of his magnets pointed in?   Engine was to collect them    coils and air cap was to use them to draw off the stones charge that is what he didnt want remaining.  He wanted the stones to repulse against like charges.
david lambright
About the line of thought that changing the sign of time in equations is changing the orientation of gravity:
The work of Fran De Aquino, freely published on the ArXiv, contains thorough description of experiments to reproduce the effect he discovered, Euegen Podkletnov mentionned him in his interview; since then, the work's more solid: here are the three main papers with two abstracts.
Gravity Control by means of Electromagnetic Field through Gas or Plasma at Ultra-Low Pressure
http://arxiv.org/abs/physics/0701091
Fran De Aquino
(Submitted on 8 Jan 2007 (v1), last revised 17 Feb 2011 (this version, v14))
It is shown that the gravity acceleration just above a chamber filled with gas or plasma at ultra-low pressure can be strongly reduced by applying an Extra Low-Frequency (ELF) electromagnetic field across the gas or the plasma. This Gravitational Shielding Effect is related to recent discovery of quantum correlation between gravitational mass and inertial mass. According to the theory samples hung above the gas or the plasma should exhibit a weight decrease when the frequency of the electromagnetic field is decreased or when the intensity of the electromagnetic field is increased. This Gravitational Shielding Effect is unprecedented in the literature and can not be understood in the framework of the General Relativity. From the technical point of view, there are several applications for this discovery; possibly it will change the paradigms of energy generation, transportation and telecommunications.
Gravity Control produced by a Thermoionic Current through the Air at Very Low Pressure
http://arxiv.org/abs/physics/0610075
Mathematical Foundations of the Relativistic Theory of Quantum Gravity
Fran De Aquino (Maranhao State University, Brazil)
(Submitted on 9 Dec 2002 (v1), last revised 24 Oct 2011 (this version, v41))
http://arxiv.org/pdf/physics/0212033v41
Starting from the action function, we have derived a theoretical background that leads to the quantization of gravity and the deduction of a correlation between the gravitational and the inertial masses, which depends on the kinetic momentum of the particle. We show that the strong equivalence principle is reaffirmed and, consequently, Einstein's equations are preserved. In fact, such equations are deduced here directly from this new approach to Gravitation. Moreover, we have obtained a generalized equation for the inertial forces, which incorporates the Mach's principle into Gravitation. Also, we have deduced the equation of Entropy; the Hamiltonian for a particle in an electromagnetic field and the reciprocal fine structure constant directly from this new approach. It was also possible to deduce the expression of the Casimir force and to explain the Inflation Period and the Missing Matter, without assuming existence of vacuum fluctuations. This new approach to Gravitation will allow us to understand some crucial matters in Cosmology.
=-=-=                               this was a post in a different forum. i believe that Eds generator made the same type of current to produce the anti-gravitational effects ascribed to him. i also believe that Hutchinson was making the same type of current flow for his levitation.
david lambright
[color=000000]Ed Leedskalnin said he figured out how the ancient stone masons cut and moved HUGE blocks of stone. places like puma-punku, balbek in lebanon etc. i believe him. working with variations of his PMH and the generator at coral castle, i found that these devices generate a visible radiation field around them. i posted videos on how to build these devices on my youtube channel, http://www.youtube.com/watch?v=lgoBFShvEpw . replicators built copies and verified my findings. what i see is a field around the devices that looks like a mirage or the "heat" coming off a hot object. this distortion is usually seen where there is energy moving upwards, like convection, away from gravity. it has been seen above electrical devices that produce large magnetic fields. it seems that where this distortion is, there is energy associated with it. i believe that Edward Leedskalnin's generator was able to make a flow of what he coined "magnetic current". not electricity, but a flow of magnetic energy. Fran De Aquino, has shown that there are different ways to achieve gravity control. i believe that John Hutchinson's effect uses the same energy as Aquino and this is the same energy Leedskalnin used with his devices. in my videos, i have a 14 pound quartz geode that i can spin with just two fingers when held near my device. i have tried to capture this energy on video but it is very subtle. Hutchinson has made metals do strange things, like get soft, come apart and levitate. i believe that Leedskalnin was able to use these currents to "soften" the stone before he cut it. some of the marks left on the stones he cut look like they were "melted". because the energy field i re-discovered is visible, is very important since the meters we have today have a hard time detecting these current flows. Aquino stated; "From the technical point of view, there are several applications for this discovery; possibly it will change the paradigms of energy generation, transportation and telecommunications." i believe this to be true. i believe that Leedskalnin's device is able to make a PURER flow of energy, made without the use electricity, using centrifugal force to start a flow of magnetic current. i believe he was able to make this energy flow in a wire, so he could use it at a remote location. a flame burns away from gravity, artificial or natural. a flame on a centrifuge burns towards the center axis. i am searching for the energy we see in rising heat,[convection?]. i believe that energy in heat is a separate thing and can be made separately. i also believe that this energy is all around us, is what every thing is made of, and very very strong. every day more and more evidence is coming to light to prove this. i am not very smart, but i am very curious and there are so many things we know nothing about. i just hope that what i have found/seen in my experiments will help us all to understand gravity/magnetism a little better. thanks, david[/color]
[/font]
