Can some explain how to tune oscilation from tesla 369 earthquake 2 power
Started by cletushowell, August 17, 2010, 11:55:20 AM
cletushowell
Ok heres deal 1.2 is not volts
its hz the coil was self oscilating to overlimit ac voltage continously
sorry had cammera problem during that
but then the 60hz coil fills with frequency
traped by the casing it essential fills the gaps
because the power does not go thru wire but around it
so they merge to 1.2 which there is no
1.2 volts in complete loops so that tells us
that we just doubled the hz
120 hz by some mathmatical
manipulation we took spirals and
completed the double hz now
why did it go overlimit let me explain
ac comes out dc goes in from the ground
i did a video on this ill post but durring
the filling of the coil frequency the alternating current
was self pulsing perfect tune of
unlimited ac volts so now theres two ways
to control oscilations from what i can tell limit the
amount the frequency builds
in the coils by some how releasing some comtrolled thru like a crystal
or take the 1.2 and figure out the circuit
to put that oscilation back in the begening
wich is probke the twisted germanium diode and transistor but i dont know any that shit so ill figure out another way
if there is another way
cletushowell
Its so much more then 1.2
its like the exact center of all energy this Is
like everything
12,
12,000
infinity
perfect hz
seperation of polarity
negative and positive
over exact center of zero point
this is the number of everything
+ =2
-=1
there is no negativd energy
only relative to direction
of Flow 2 are coming or going
but when you turn 1 into 2 again
your loop is complete
on both sides had a bad day
in the most complex part
interuptions all day
Low-Q
Quote from: cletushowell on August 19, 2010, 03:16:51 PM
It very simple if they dont have 144,000
thhere false doctrin works of casting 9 marco rodin
nimrod the 666 m rodin
so it worked its very simple when you tune the osxilations
its goes overlimit contiously i had it perfect
but now stuck on the very top post the 1.2
so if you dont even understand. The 369
your wasting my time I didnt say this was a education
forum I said if you know how to tune oscilation
so mr vidar do you know how to tune it
or just going to keep degrading my
free energy
car coil from negative dc to positive side of coil
polorise it thru the negative side to ground rod
then add spiral square wave creates the secondary
ground if i get it circling in over limit again ill post the video
For what purpose are you tuning oscillation?
What do you mean by tuning?
Do you want higher frequency?
Do you want 369Hz?
Do you want to connect a negative DC to the positive side of the coil, then polarize it through the negative side?
Then add a "spiral square wave" that creates a secondary ground.
What is a spiral square wave? I cannot understand it by the explanation in your video.
Then you hope this will loop back into the beginning and start making energy?
There are according to the Bible 144000 people that will go to heaven. 666 is the number of the Beast, but I do not think these numbers are going to help...
You can tune the frequency by rectifying the 60Hz AC with a bridge rectifier. Then connect a capacitor in series then a small load to ground. The capacitor will be charged with DC and therefor alter the 0-level. So now you got a new AC component over the load which contains a bunch of harmonic frequencies. You can then make a LC circuit that is tuned to any given frequency equal to n x 120Hz (2 x 60Hz ater rectifier). That would be for example: 120Hz, 240Hz, 360Hz(Pretty close), 480Hz, 600Hz, 720Hz, 840Hz, 960Hz, 1080Hz, 1200Hz, 1320Hz, etc, etc.
Then you will have 666 Volt from a Marco Rodin coil - 9 of them?
The number 9 are used in religion too. Thats why you mentioned Bin Laden I guess. Islam use both the number 11 and 9 as holy or bad numbers. The incident at the twin towers happened not by "accident". The date was 9/11, the twin towers represent the number 11, the most great name of God are also number 9.
Hmmmm...so this is the reason for these numbers, and you therefor believe these numbers carry a some sort of secret that will reveal great amount of energy?
OK, I start to get it - I think. There will most probably be no OU out of this though.
EDIT: It is the numbers 3, 6 and 9 your'e at - not 369?
Vidar
cletushowell
Sorry vidar
im doing my best kinda steaming right now
first you are correct 9 11 are both the same
IX XI
do this 1 cronicles do what it says
add them you can watch my 666
video if you want but i tell you add all the names
you get 47 on nimrod the only son whos begot
not born many have caught on he does
not blink nimrod is m rodin
there both over unity it a war between me and him
the difference is in 9 and 11 theres massive destruction
haiti huricain katrina 911 the oil rig
the tidal waves all these are man made
now in perfect frequency theres no damage
mariana islands 6.3 6.6 6.9 7.2
and there like 25 more
but those are the most important if you see the grid
they all landed on 12
so marco rodin his feet are like a bear
the biggest russian plane
his dad is oud top nuclear scientist his brother
runs the fiber optics
and theres much more hes in Nasa
and the hospitals even the cloning
the coils a joke compared to his power
infact he didnt build that coil he built optics
and the goverment converted it to a wired coil
but his coil is wrong you understand electricity more then me
odviously but the coil is not what he built
lool at the colors on his video red blue its a plasma
like the plasma ball you stick your finger on
well im going to calm down try to understand what you said and start again
cletushowell
Seriously whoever classified these phones
as 3 g needs to be shot if there 3ghz
why the fuck do I have to wait five minutes for it to load the dam
uhf tv loaded faster then this bs
maybee 3g for everyone not 3 g per phone
anyways it split the 60hz into
1.2 ghz now when I figure out the
magnification it will be you coukd see
if 60hzx5 volts dc =30vac
then 1.2 ghz x 1 volt has some potential
ill go test in a bit
