Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
rock321
Hello Again,
This is not a measurement error. I'm getting double the voltage and double the current when I connect these two "crystal" batteries together in series. When I measure the voltage and current with just one of the batteries, I read half the voltage and half the amps. When both connected in series, I get the doubling of both. Therefore this cannot be a galvanic reaction taking place in these cells. If what I understand from the Lord is correct, some further experiments should reveal some more interesting results.
Also, these two batteries which take up only 1 1/2 inch by 1 1/2 inch are now able to power a 3.5 volt LED, up from the 1.7 volt red LED.
Blessings,
Littlechristgod
jeanna
@rock321,
gotta pic of these together with the meter?
@das,
I really cannot answer most of your questions. I was playing around with Davidovits silicate materials when dani first opened this thread. I only joined to pass on that info I passed to you yesterday.
Then I tried some of the things myself.
You can make potassium silicate which might have slightly different characteristics.
It was when you said that reid uses heat that I looked up davidovits again.
If you make the silicates then mix in some powdered rock, you will get a rock after time, if you do it right.
Once you add a little heat, it will make a very hot reaction and cook itself.
I never heated mine.
The youtube videos show more clearly what needs to happen to make a solid rock, and I can say now, I never did it right.
I was not sure I ever had the chemistry right either, but I think this all should be close to making a working non-galvanic crystal. You might need to wait 30 days to find out how it is. It seems to me that if you add various rock powders, you should find the promising ones, and later combine them.
This group has already made many material trials and failures, and can offer a good base for more research.
I believe Marcus reid and hutchinson are both closed mouth and we must make our own research and share it.
I got lots of volts (2-3v but virtually no uA), but whenever things became dry the charge stopped. It also ate through the aluminum foil I was using for electrodes.
Silanes and siloxanes are things to look into also, imo.
jeanna
das aloda bullspit
also one thing i ould like tokno is uat happened to koen and his cells i havent heard from him ina long time are his early cells the one next to the v dink still orking and there are a lot of other questions
das aloda bullspit
got one mix for ya to try
Kaolin not alot
euxenite
sodium oxide
potassium silicate or sodium silicate
barium titanate if you have any
si02 of silica i think it is ?
titanium oxide
silver oxide?
cobalt oxide ferric  oxide
not sure about calcite but you can try
redcopper oxide rod
aluminium oxide
and some crushed up rocks not sure hat they ere put together and leave ithout polarization its about 0.4 volts not sure if polarization ill do anything  also the silicate cels from earlier on in the thread  koen1s v drinks can cells and ians uhite pie cell and all the others hat happened to them are they all still orking last i heard the pie cell as at 0.5 volts ian is it still as good? one thing ive notaced ith one of my cells it that out of the ay of my computer it drops to 0.2volts but hen in front of it it rises is it an electrostatic cell/ it shot up druing a lightening strike
mscoffman
Web Link - Potential plug-and-play low power loads for long lived
petrolithic batteries;
http://www.nytimes.com/2010/07/18/business/18novel.html?_r=4
Using RF for energy, one is on a slippery slope towards ever more
unintentionally intercepted power.
:S:MarkSCoffman
