My free energy experiment.
Started by stevensrd1, September 12, 2010, 11:07:25 AM
shylo
Hi Steve when you say you wired the two cd motors in parralel ,...since they are facing each other like in the photo .....one is spinning cw while the other spins ccw ,... because the motor I have spins ethier direction depending on polarity...........still trying to find a 2nd cd motor to try this exp. ......a schematic of new test would be greatly appreciated....not quite sure what the exact layout is......thanx for any advice ....shylo
stevensrd1
First of all,,the update,,I ended the experiment for the 2 recharging 5 bats around 5:20 pm, it did not end up well at all, as I did the big drain test with my 3 inch motor and it only ran about 5 mins. For those who have not kept up with the post,,the big drain,,is a motor I use to drain a single 1.2v battery. It will flat drain a fully recharged battery from my plug in ac recharger in about 10 or so minutes,,and yes the battery gets very warm doing that, but its a fast way I drain them. And I can test the power stored in a battery that way by timing the drain. So I had the numbers but not the power. So it seems I can only go as high as 2 bats recharging 3 and still keep the actual power so to speak,,or should I say amps,,oh well. I will repeat this experiment again just recharging 4 bats and see how that goes, perhaps tomorrow. Still was a fun run. And I still think 2- 1.2v bats recharging 3- 1.2v bats is still very nice.
Shylo,,all is the same thats on the last schematic but the motors are as shown in the picture I took, and you wire the motors so that they both spin the disk in the same direction...
stevensrd1
Thought I would upload a picture of my main drain motor, those reading the post know what I use it for. It will run on 1 AA battery but not very fast, and it will drain an AA battery in like 10 minutes or so. It takes alot of amperage to run this motor.
stevensrd1
Ok,,I may have figured out a way to get two AA batteries to recharge 5 AA batteries. If you kept up with the post,,you know we can recharge two AA batteries with two AA batteries with the 1 cd motor experiment. You also know we can recharge three AA batteries with two AA batteries with the two cd motor experiment. Which does a better job at it then using the one cd motor experiment to do that. You also know that my last attempt to recharge 5 AA batteries with 2 AA batteries did not work out so well, as I got only around half the recharge with that one. Now I been thinking about this and got another experiment going thats a bit different in design but not alot different. I been looking at the problem half way backwards, took me some hard thinking to figure this one out. See on the one cd motor experiment I use the motor not only for looks or to show something can run while the recharge is going on. But the cd motor is also acting as an electron pump, this and the actual design or way the batteries are wired helps make this all possible. Now as to my two cd motor experiment, I got a better recharge but at less run time. But that worked out well, as both cd motors were acting as electron pumps, delivering a better recharge,,with minimum actual energy drain overall from the batteries while doing this. Originally my reason for adding the second cd motor was to ease the overall load on the first motor. That worked out ok too, but then we had two motors doing some draining on the main batteries as the other batteries were being drained. It was a tricky position there. Now the way I figured out how to recharge the 5 AA batteries with two is by using three AA batteries. But its not like you might think, in truth its still only two AA batteries recharging the five AA batteries, as the third main battery is completely out of the circuit loop for recharging. See I use the third main AA battery to power the top cd motor on my two cd motor experiment now. Now Ill tell you what,,when I was first experimenting with this earlier,,I was recharging two AA batteries with two AA batteries this way and I seen not only was the recharging batteries rising in numbers on the meter,,but so were the main batteries rising as well. There may or may not be something to that Ill have to get back to it as since I thought of how to rig it all to recharge the five AA batteries, I quickly did so to test it,,and the test is underway now.
And the main batteries are slowly draining here,,so its not doing the same as the two battery experiment before this one. So back to how this is working, If you take an AA battery and hook it to a motor, and let it run,,and hook a meter also,,you can watch the numbers slowly fall as the motor slowly drains the battery while running right. But if you pay attention to the direction the motor is spinning, then let the motor drain the battery,,then spin the motor by hand in that same direction as it was spinning, with the meter hooked up,,you see the numbers rise. So in effect your recharging the battery that way, by simply spinning it the same way it was spinning when it ran and drained the battery. SO on my two cd motor experiment now, the top motor is powered by that third battery, that is not in the recharging loop. But it adds spin to the bottom motor without any drain on the main batteries,,and this adds the extra energy to get the 5 AA batteries recharged, at least thats my theory for now. The test is underway,,the motors are zooming and have been some hours now, when the test is over I will see if the 5 AA batteries took a good recharge and are holding their amperage and Ill come back here sometime later and write the results,,wish me luck...Oh If this works out well Ill also make a schematic, but overall nothing is changed on the two cd motor experiment except a third battery is powering the top cd motor,,and that is a separate circuit,,not in the recharging loop. So more later...
petersone
Hi Steve
You are putting a lot time and work into this,hats off to you,you have my admiration,keep the reports comeing.I'm following every post.
peter
