Friction heater running in my house
Started by oilpiggy, October 31, 2012, 02:25:24 PM
MileHigh is banned now from this thread.
tagor
Paul-R
Quote from: Paul-R on December 20, 2012, 10:27:40 AM
I agree. His work is interesting,. especially the magnetic discs, a departure from Frenette
and possibly bringing in Schauberger, vortices and Lords Knows What.
In fact, if the fluid is electrically conductive, I wonder if there are issues to do
with unipolar generators, bruce depalma and all that.
oilpiggy
Hello everyone,
I hope everyone had a good new year start. I am looking forward to this year and everything to come!
I am working on some new tooling for this next Friction Heater build, it is taking me longer then I was thinking but I only want to do it one time not two. Best to take my time. I have also started playing with electric magnetic toys I am making. I will post about them when I am done with my prototype. It has a cool factor and fun.
Best wishes
Gabriel
Bruce_TPU
Quote from: Bruce_TPU on December 23, 2012, 12:23:23 AM
Huh??  Not "playing" any sort of "cop".  Simply answering MH post to me earlier.
I have already said that I find this heater "interesting", and actually took some time to research it, the history of friction heaters in the FE community, and spoke with Gabriel via email.  It is a detailed build with precise measurments.   I also found the idea of combining several ideas within the friction heater, "intriguing".  I actually like to build things, not just talk about them.  So my own version of a friction heater might make for a fun project.   ;) :)
Using the following idea, combined with nanoparticles mixed with the oil, to heat the oil and use as a heater (not as a water heater).  Same idea of friction heating the water.  This seems a bit more efficient at first glance to me.
http://www.youtube.com/watch?v=yh_-DUKQ4Uw
Cheers,
Bruce
Hi Gabriel,
Thank you for the update.  Did you have a chance to look at the above youtube video?  Same idea, as far as friction to heat, but a very different design.  I would be interested in hearing your thought on this type of set up.
Thanks,
Bruce
