1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
scianto
I can confirm that this kind of an air transformer (which it is in its essence) is 80 to 90 % efficient.
I did some rough tests today, here is one of them:
http://www.youtube.com/watch?v=-JSvSFugWwI
having some lab experience with frequencies and waves like these one I am pretty sure that this setup is less then 100% efficient.
The efficiency can be higher when the output circuit is put in RLC resonance, but I don't think it will be higher than 1.
(I am talking in Polish -- no time to translate yet, but I plan to.)
Magluvin
Quote from: Magluvin on December 29, 2012, 10:14:15 PM
In JLN's vid and Woopies vid, it seems the transmitting coils are standard pancake and the receiver coil is bifi.
TK shows that the bifi is a better transmitter than a receiver.
http://www.youtube.com/watch?v=mvb39SwTXBE
Mags
So, I wonder if the coils can be exchanged? Put the bifi in the heater unit and the regular pancake on top as the receiver? ;)
Mags
Magluvin
In the heater that Naudin opened to show, it appears that the large heat sink on the circuit board is right under the induction coil. Why does that sink not heat up from induction? It looks like it is right under. ???
Strange.
Mags
crazycut06
Quote from: Magluvin on December 30, 2012, 02:54:27 PM
Strange.
Mags
Hi Mags,
I think only metals can be detected by the induction cooker, i had an ordinary metal pan and it activates the cooker and heats up, while the alum based pan doesn't.
I smell somethin's cooki'n! Lol... ;D
crazycut06
Quote from: e2matrix on December 30, 2012, 01:06:50 PM
Did you see he also showed AC voltage and current output?  I know that may not be the most accurate way but could it be that far off?   Isn't the induction heater a resistive load?   If so would it be possible to loop this?   The electronics in the induction heater might not like it but you could probably bypass them and just hook straight to the induction coil.  Or make your own.   Give it a jump start from the grid and have a relay flip it over to loop it?   Sounds easy enough to try.   Wouldn't that be a hoot if that's all it took....
Hi e2matrix,
Is an induction cooker a pulsed dc system? If it its maybe the output will not be pure sine, but pulsed dc?
