Solid State "Synchro Coil".
Started by synchro1, March 31, 2014, 11:02:53 PM
synchro1
The spiral bifilar toroid blows a "Magnet Wave Smoke Ring", the hole in the smoke ring is the hidden north pole that powers the vortex. 0,A0) The paired couples. Born from the destruction of two mutual fields!
synchro1
The definitive video on the secret of the "Quantum Quadrode Amplifier": Imagine a powerful neo diametric tube magnet with output coils wrapped through and around the bore hole, positioned stationay where the compass is and fed the  same oscillating sine wave! Anyone wonder if the magnet core coil can exert any kind of Lenz drag on the bifilar A.C. current? We can gang the  "Lenz free" magnet coils up in spoke pattern to maximize output, right?
https://www.youtube.com/watch?v=wd5w8KhYrQk
synchro1
Here's a patent for something very close to my new idea:
synchro1
The big difference between TK's spiral and the QQA is that the thick wire spiral bifilar toroid primary projects a field far enough away from the coil to prohibit the magnet core output coil from reaching back and raising impedance in the primary as the magnet coils would do on the TK's bifilar spiral, and the ferrite cores in the invention above.
A resonating LC tank would sustain a coil field in these magnet replacement coils for practically nothing. Might take a tuner capacitor to keep the adjusted resonating frequency in harmony with operating system hertz.  There's no draw on these coils because they don't do any work. The work is done on this coil field by magnetic induction from the sine wave reactive field. The spiral bifilar primary has no magnetic field in the coil because the mutual fields canceled out. The oscillating field comes from the A.C. current and the reactive field is amplified through the bifilar torus when the collapse occurs. Magnetic field forming reactive collapse and frequency are directly proportional. Higher A.C. frequencies would generate higher output!
synchro1
TK said he thinks it would heat up. My answer to this problem would be to build a twin, and reciprocate the two to include an adiabatic cooling cycle. This would require splitting the output bifilar, pausing the primary A.C. current, and pulsing the magnet with D.C.. The second bifilar winding would collect the demagnetization output, and return it to the source capacitors. This would cool the magnet. The sister coils would be on the A.C. magnetic induction heat producing output cycle. One side generates current while heating up and the other side while cooling down!
Rather than a permanent magnet core, a D.C. coil with a sustained field, and Barium Titinate core would maximize the output from the cooling cycle.
I believe this is what the RMS transverter circuit's like that Aaron's sponsoring at over 40 times OU on Energetic Forum.
